Feral Feline
I tried laying it out a couple ways but keep coming up with something that is on one side of the chip but needs to be on the other.
So then I started trying to swap* the op-amps...
Pin 7
Pin 1
Pin 6
Pin 2
Pin 5
Pin 3
Pin 3
Pin 5
Pin 2
Pin 6
Pin 1
Pin 7
... to try and get a better flow — and I'm still getting stuck with one thing or another that doesn't belong, the Trimmer for example.
*NOTA BENE! If you swap pins, make sure they're the right ones, as the schematic is drawn such that the neg-input is on the bottom for the first op-amp, but on the 2nd op-amp the neg-input is on top. Luckily I noticed this right away, so my painting myself into a corner isn't because of that.
The next thing I did was try to group components by nets, assemble little clusters of components and then route from cluster to cluster but that just turned into one big clusterfu...
Now I gotta go shop for groceries, Saturday, Christmas Eve, in freezing weather with last-minute-shopper-morons running red lights on roads that are slicker than hot whale-shit on an iceberg. I guess that makes me a last-minute-moron, too, shopping today, BUT ... I couldn't go for groceries prior due to work and ...
I won't be running any reds.
Travel safely out there, everyone.
Pin 7
Pin 6
Pin 5
Pin 3
Pin 2
Pin 1
