steviejr92
Authorized Vendor
The exposed copper looks killer! Is that an option you have to select when ordering?
The after dark boards are beautiful, but pretty expensive.
Another option that seems to work well with JLCPCB is having exposed copper instead of silkscreen:
It’s part of the design process and is included in the gerbers. I use EasyEDA, but the process should be similar regardless. You do a copper pour (ground plane) and then select areas to not have solder mask. In EasyEDA, I was able to import an image in the solder mask layer and that the image would be the only area not covered by the mask.The exposed copper looks killer! Is that an option you have to select when ordering?
Dude thank you so much for sharing this! I’m still new to all of this, I knew I could do it I just didn’t know how lolIt’s part of the design process and is included in the gerbers. I use EasyEDA, but the process should be similar regardless. You do a copper pour (ground plane) and then select areas to not have solder mask. In EasyEDA, I was able to import an image in the solder mask layer and that the image would be the only area not covered by the mask.
Here's a picture of what it looks like with the copper pour hidden.
Since the 'sand white' isn't really 'white', you may have to have an exemplar to really judge the substrate and inform the color choice. Sorta just guessing otherwise.I finally finished up some graphics files, and I'm just prepping them all for printing. One I'm doing is sorta a stealth white thing- Gloss 'white' on a white sand enclosure. Anyone have a suggestion for what shade I should go with for the printing to make it a bit less invisible while still having a stealth white look? Right now I have it set as a 5% grey (f2f2f2), but I wonder if perhaps something half as dark (f9f9f9) might pop well enough once the gloss is there to cast additional shadow. Anyone have thoughts?
Good to know. I haven’t done any sand white stuff yet, but it appeared to me to be a textured titanium-white sort of color. Is it more of an off-white, or more of a neutral-temperatured very light grey?Since the 'sand white' isn't really 'white', you may have to have an exemplar to really judge the substrate and inform the color choice. Sorta just guessing otherwise.
I'm not sure exactly. I just meant that 'white' can mean many different shades. If you're looking for subtle or 'stealth,' you'll probably want to do some color measuring to ensure you get the effect you're going for.Good to know. I haven’t done any sand white stuff yet, but it appeared to me to be a textured titanium-white sort of color. Is it more of an off-white, or more of a neutral-temperatured very light grey?
Ah yeah, I get that. If I’m just doing grey ink and clear without a white layer it should maintain the same color temperature though— just a matter of how much it’ll “pop”I'm not sure exactly. I just meant that 'white' can mean many different shades. If you're looking for subtle or 'stealth,' you'll probably want to do some color measuring to ensure you get the effect you're going for.
I really dig this! Looking forward to see the finished pedal
