Hello,
this is the first guitar pedal I built and I have some problems.
First of all the out of the four leds only two work. Of the two small leds, only the top one works (hard to see in the picture), and out of the two bigger ones only the right one works (constantly on). I get a Chorus effect with a very fast rate with all the pots turned down and nothing changes when turning any of them up. So the effect is always the same. Also when the effect is turned on, the bigger led is off.
Some additional info: I set the trim pot to around 6V and already resoldered most components.
Let me know if you require a detailed view of any component.
Thank you, I appreciate any help
