swyse
Hey guys, I wanted to share another project I've been working on. This PCB I designed is for building a klon centaur, bluesbreaker and ts-10 3n1 with separate jacks to change order or use them with other pedals between if desired, or klon>bluesbreaker>ts-10 if no jacks are inserted. I took some liberties changing component types, using film and non polarized in the audio path. It also has two DC jacks, with one of them being switching so it disconnects the other so both can't be used. I did this for better compatibility with the different sizes of patch cable ends potentially blocking the top DC jack. This monster took me 6 hours and 15 minutes to build, but I think I could get that down a lot with a PCB revision and using my pcb software to locate all the resistors digitally haha. I was glad to be done soldering and assembling so I forgot to get it all cleaned up for the pictures. The demo is from the first one I built before I added a bit more contrast to the graphics so you can actually see the swirls haha. Also the ICL7660SCPAZ I got from tayda had a whine so I had to pull one out of my other klon clones so I could get this out to the customer ASAP so just a heads up I'd skip that and get a 1044 from them instead as I've had good ones of those.
