kingbarnes
I'm seeing that there are different types of 3PDT switches, meaning there is different wiring!!! I'm seeing a 3PDT PCB from stompboxparts.com that has wiring that only matches some types of footswitches but not others, and the usual template from PedalPCB.com:
And this shows wiring that is completely different. It also mentions some switches are compatible and some are not.
I had a thread about my Underminer sub-octave pedal having no sound when the footswitch was engaged. I built a second one and same thing. There were no issues that I could find, but now i'm thinking i have footswitches that should be wired differently than what I've usually done, which is what's shown above from pedalpcb.com (which i had 2 previous successful pedals but those had different 3PDT switches than what i used in the 2 Underminer pedal builds).
So I'm thinking it's worth tyring to put the 3PDT on a board from stompboxparts.com, wire that, and see if my pedal builds then work. It does make sense to me that this could be the cause.
Thoughts?
Thoughts?
