nate433
Alrighty to the breadboard thenI was just tossing out ideas. No idea how well they would work.
I changed R13/C11 from 4.7k/56n to 470R/560n and it works as a heavy distortion now.I wish it had a lot more gain out of the OD.
You could mess with R12, add in a pot there to get more volume out of IC2.1 — it's already at 1M, though; also, I've no idea if that's the "FUZZ" side of things or the transistors are what's Fuzzy....
Do you also think it would be possible to add a gain or volume control for the fuzz? Since apparently there's can be a bit of volume drop when setting it to 100% fuzz. Maybe even add a recovery stage after the fuzz ONLY if it's set to 100% fuzz or even attach it to the aforementioned stomp switch somehow?
Transistors are the fuzz side, op-amp is the OD. If my memory serves me correctly is a modified and juiced up DOD 250 (maybe Distortion+)You could mess with R12, add in a pot there to get more volume out of IC2.1 — it's already at 1M, though; also, I've no idea if that's the "FUZZ" side of things or the transistors are what's Fuzzy.
Alternatively, you could just add a boost at the end of the whole shibang. Either:
- A 2knobjob on the FUZZ using a 4PDT with the 4th pole used to activate the boost-circuit when the fuzz is maxed out.
- An Afterblaster utility stomper-bypass with a DPDT footswitch to activate the boost instead of the dip-switches.
Is the 5th control based on the thread linked at reply #24 ?New modded clone with a 5th control.
