OcelotI've just been hipped to the notion of OCTAVE DOWN for bass.
Problem is, all my octave machines add dirt. Is there anything clean for bass that isn't digital (i.e is buildable?)
I forgot about this one, I’ve built it as well.Thanks Jimilee. I added Ocelet and Octarock to my cart before posting, but I suspect the fuzz can't be disabled on the Octarock. Still researching. (The Octamizer looks intriguing, but not traced anywhere AFAIK.)
The 2nd octave down of the Ocelot is probably useless for bass, so ideally I'd find a 1 octave down + 1 octave up that tracks well with bass, but if not, the 1 octave down on the Ocelot will suffice.
AND, @xefned, it's DIY-able — available through Lectric-FX.DOD Meatbox if you want control over your bass frequencies down to deep subs. It goes about it differently than the standard 4013 circuits, and has really wide EQ options and serious balls.
The second octave is pretty common for dubby synth tones on bass. The first octave is the classic Tony Levin Sledgehammer tone
Thank you. I'm now on the waitlist for this one. Since Madbean's Lowrider is discontinued, this seems a good alternative.I forgot about this one, I’ve built it as well.
"Up, Down, Daddy!" PCB - delyk PCBs
My daughter melts my heart when she asks me to "Up, Down, Daddy!" when throwing her up into the air and catching her. I figured this was a perfect name for an octaver with 1 octave up and 1 and/or twowww.delykpcb.com
Meatbox looks fantastic.DOD Meatbox if you want control over your bass frequencies down to deep subs. It goes about it differently than the standard 4013 circuits, and has really wide EQ options and serious balls.
Gotta try it just for something different. If I can find a non-counterfeit M51134p, I'm all over this.AND, @xefned, it's DIY-able — available through Lectric-FX.
Middle position (!!!) could inspire some interesting basslines. PCB also at Smallbear.The Parasit U-235 is amp great clean suboctave too. The middle mode is especially rad
A brilliant legendary circuit worth considering is the Downtown Fuzz (you can turn off the fuzz) :
Amazing, both with bass and guitars.
I think I'm going for Levin, at least for recording. Usually, I want the effect to be not overtly noticeable by the average music listener. But I'll give that 2nd octave a try to see for myself. Could be ear-opening.
Dang this just made my day- was looking for one back during the peak of the MB RI hype and these used to be expensive af and near impossible to find. Honestly kinda surprised that there's this many still out there.The chip is available. There should be no reason to counterfeit it.
