Tone vendor bender mk2 bias
Rimgrot
Hi!
I'm currently building a Tone Vendor mk2. Bought a transistor set from Smallbear which came with the following components:
Q1 2n1305 - hfe: 67, leakage 40
Q2 OC75 - hfe: 70, leakage 270
Q3 2n1305 - hfe: 103, leakage 10
Smallbear suggest the following bias resistors:
R3 100k (R5 on the tone vendor pcb)
R4 91k
R6 6.2 k (R7 on the tone vendor pcb)
I have breadboarded the circuit and It works, but output volume is a bit low, about unity gain with the volume pot maxed. And the fuzz sounds undefined and gated/little sustain with attack pot on max.
The collector voltages with 9v power supply are:
Q1 c 8,29V
Q2 c 0.178V
Q3 c 8,7V
Is it possible to bias this circuit better? I have not tried any other Tone Bender circuits before so I am a bit unsure what I am aiming for and how it should behave.
Thanks!
Hello, welcome !
You can have a look at Aion's tonebender mk2 build docs (p.5, 6) for more info about the biasing :
If you want to be be as accurate as possible, i guess you have to use some trimmers to set the bias resistance. Once you found the right values, you can solder the proper resistors.
If you can't compare with an original unit, you'll have to trust your ears, and find the sound that suits you the most.
From what I could gather, you chose to build the most difficult tonebender version. Mk3 is easier.
"Germanium transistors are notorious for being extremely temperature-sensitive, and as the ambient
conditions change, gain and leakage can vary drastically.
(...) if you notice the unit get noisier as the seasons get colder, it’s probably because Q1 is not
consistently leaky enough. If you can’t change the ambient conditions then you might need to change
the transistor for one that has an even higher leakage."
Hello, welcome !
Hello, and thank you for answering. I have looked at the docs from Aion and will try putting some trimpots on my breadboard. I happened to have both a 10k and a 50k trimpot so will see if I can get it sounding better.
Will a more correct bias also affect output volume?
One of the reasons for posting in this forum was that I have seen many different recommended collector voltages for this circuit (from 7-9V on Q1 and Q3), so was also hoping for some insight regarding what voltages in comparison to Hfe and leakage, if that makes any sense.
I also got a matched set for a mk1 from small bear, but thought it would be easier to start with the mk2 since it had been tested and came with recommended bias values.
Have you tried using the stock values instead?
In my limited experience with the circuit, an MKII should sound like a Fuzz Face but with more gain and more treble (with Attack maxed out). It should should huge.
It should still clean up completely by rolling the guitar down to 2.
If you lower Attack, it should clean up at around 5, so basically like a Fuzz Face.
If you want more output, lower the 8.2k resistor on Q3c and increase the 470R accordingly to maintain the same total resistance. However those voltages are not set in stone. Anything from -8V to almost -9V should work.
Hello, welcome !
I think the MKI is the hardest to build because unless you have just the right amount of fuzz and leakage it sounds weak or too dark and it's full of ugly artifacts in the decay of the notes.
The key to all Tone Benders is enough leakage. It naturally brings the voltage to the right spot without losing the fuzz character.
The problem is the seeming randomness in the response of transistors. Some that should work don't and others that shouldn't work do.
Hi, and thanks for replying! I tried the stock values first (Tone vendor-values). They sounded worse as in more gated and little sustain. The circuit sounds a little better with the bias values from small bear.
I recently built a fuzz face which turned really great. Compared to that this bender circuit doesn't sound huge and not so trebly. The bender cleans up a little bit, but not in the same way as the fuzz face
Thank you for suggestions regarding output volume. Will try this after tinkering with the bias resistors.
I would inspect the board and your joints. You are not getting much voltage dropped across the Q3 collector.
Even with that thought, the voltages are high. Furthermore, Steve at small bear used erroneously target 4.5 vDC on Q3 and his resistor values reflected that. Assuming Synth Cube uses his notes for testing, something is certainly amiss.
Your output issues are almost certainly
Because of extreme gating.
First rule out poor craftsmanship and soldering and then we can start working on tweaking the bias.
Thank you for responding. I haven't soldered the components to the PCB yet, it is still on my breadboard. I have checked for continuity and that the components and values are correct with my DMM.
I have attached some pictures of the breadboard, though it is difficult to make out connections on the photos.
The supplied voltages are with the suggested bias resistors from small bear:
Q1 c 8,29V
Q2 c 0.178V
Q3 c 8,7V
What happens when you change R1 and R7 to 10k?
Here are the voltages with R1 and R7 as 10k:
Q1
C. 8.67V B. 11mV E. 0.00
Q2
C. 250mV B. 85mV E. 0.00
Q3
C. 8.58V B. 250mV E. 190mV
I am assuming you meant R1 and R7 from the pedalpcb schematic.
It's a bit late so can't test how this sounds until tomorrow.
Try that and I have more tweaks to try as well.
Ok, have tested it with 10k in R1 and R7.
To me it now sounds more destroyed and reminds me a bit like a bit crusher. I think the volume output is a bit higher, and the notes sustain for a while, but the dynamics when I pick the notes is very flat and compressed. Chords or more than one note sounds very mushy and undefined.
Overall I think I liked the sound better as it was before.
I can try to upload a recording if that is helpful?
Can the gated sounds in the decay be caused by the biasing of Q3 or a combination of all the transistors?
not sure if its helpful but i have heard that using a starve pot to lower voltage can cause gating in these 3 germanium transistor builds.
FWIW . . .. here are some links to BJT Biasing Calculators . . . .
(I just Googled "transistor biasing calculator" and got a good list of sites.)
Transistor Biasing Calculator
Calculator Edge
Peter Vis
Alan Yate's BJT Biasing
Personally, I prefer to use trimpots as biasing elements when breadboarding Ge dirt circuits. Once I find what "sounds good", (as opposed to what the measurements are), I jot down the resistance value and go from there to make whatever combo of resistors are needed to achieve the biasing resistance.
No that's CHEATING, they have to bias POIFECTLY with the stock values or you're disqualified!
Only a Cybercow would taint a sacred germanium circuit with trimpots...how dare you!
I have an MKII on a breadboard that sounds good and Q3c is at -8.17 V. No gating.
Hi!
I'm still struggling getting the bias right. Have tried with trimpots along the lines of the Aion build documents, but can't dial in sounds that really work.
Went back to using just the resistors on the breadboard and currently have the biasing resistors set up like this:
R1 100k
R4 88k
R5 33k
R7 47k
This gives the collector voltages:
Q1 8,23V
Q2 283 mV
Q3 7,63 V
The sound is no longer as gated and produces more volume. I can dial in some nice and very usable sounds with the attack pot on a low setting, but higher and full attack is just to gainy, mushy and too distorted.
I get a bit lost with so many variables and I am a bit uncertain about which components to change to move the circuit in the direction I want it.
Does anyone have some suggestions how to get a lower gain level?
Can you post an annotated Aion schematic showing all the values, including capacitors, that you have installed? Also, what amp are you running this into? Amp settings?
I have used the attached schematic for what I now have on my breadboard. I have written the name and values I have changed in blue on the right hand side.
The Aion schematic was suggested earlier in the thread as an example of using trimpots to adjust the bias: https://aionfx.com/app/files/docs/deimos_legacy_documentation.pdf
I just used the trimpots + related resistors from Aion to the PedalPCB schematic.
I have tested the effect on a Fender Princeton (cleanish) and with my Vox MV50. I have tried settings from clean to overdrive.
Insanely late reply on this, but if you still have some version of this breadboarded @Rimgrot, I'm pretty sure that OC75 is meant to be your Q1. Swap it with Q1 and this should bias pretty well. As-is, it's gonna be difficult to get enough current flowing into the collector of Q3 without some pretty large tweaks.
Put OC75 in Q1 and put the Q1 2N1305 in Q2 and it should bias fairly well with the Smallbear values and won't be far off with stock Mk2 values either.
From my experimentation with MKII Tone Benders, Q1 doesn't need high gain and high leakage. A gain of 60-80 and >60 leakage seem to suffice. Too much leakage in Q1 creates a lot of noise. Q3 needs more leakage. The goal is to get Q3c close to -8V naturally, without messing with the bias. This will give a bright, raspy tone but still sound like a fuzz.
Raising the voltage that high from -4.5V in a Fuzz Face, conversely, can only be achieved by lowering resistance to the collector and that will make it sound more like an overdrive. It gets brighter but it loses the fuzz quality.
Of course original MKIIs all sound different but I think we can all agree they're supposed to be like a Fuzz Face but with more gain and more high end, and the Attack knob gives great tones across the whole sweep. Mine sounds best halfway up. It goes crazy if I max it out. Btw I need to box this thing up!
Correct me if anything I said is wrong!
