Ambassador - Matchless Hotbox project
Almost done with the build doc on this one, just need to update the build instruction pictures and the drill template. I have 8 PCBs on hand and a lot more on order, I'm planning to make the 8 available as soon as the build doc is ready, then add a lot more when the new batch comes in. No changes were made to the PCB at all, the new boards will be identical to the ones I have on hand already.
If you want to go all out:
Limited Edition Transparent Gold
If you want to go down this Rabbit Hole, it gets expensive!!!
Around $85.00 US, you can't purchase the Enclosure without the Klon Drill pattern!
You have to Weld or JB Weld up the holes & Paint it
There are some internal lugs that may have tbe removed:
Then there's the Vent slots.
You can get away with the Power, Input & Output jacks!
This is just a Mockup, I wish the Real Deal was so simple but it aint! :
UPDATE:
It has been bought to my attention that there are enclosures that look similar in the overall look but are smaller & are available with no holes.
I knew about the smallest one which is very similar in size to a 1590BB but there is one that is between that & the full size Klon replica!
They both have no holes or internal ribs??? to worry about either.
Stay tuned!!!
Yeah unfortunately Ambassador isn't the best candidate for a Klon enclosure. Black Eye, on the other hand, works well.
UPDATE:
Stay tuned!!!
For the sake of DIY Pedal Builders:
Thanks Bricksnbeatles for the link (y).
There is a Medium size Klone look available that has no internal ribbing & is not drilled:
It may be an issue with the Rounded corners, I have one on the way so I will find out when it arrives!
How Much!, $60.00 AU shipped!!!
I don’t think the one coming for me will look like that!
Unfortunately no, I'm not in a position to offer full custom enclosures. One of these days I may get around to putting together Tayda drill templates for all my stuff so people can have more options than just bare enclosures from me, but it hasn't happened yet.
