Phase II too subtle
Ludovic
As a beginner with poor knowledge in electronic, I built the Phase II from a Musikding kit. I'm not that happy with the result.
1/ I have to fully close the 10K trimpot for the yellow LED to start blinking, and fully open the 1K trim to have a decent sweep.
In the end, the phase effect is very subtle, even with depth maxed out.
Is it possible the LED specs is not adapted to the circuit? How can I double check that? Is it worth trying to pair the led with an extra resistor? Which value? Or maybe I should replace the 10K trim by an higher one?
2/ I was expecting the phaser to periodically gently boost low ends during the sweep. That never happens. It this the normal behavior?
Thank you for any suggestion!
While it can definitely do subtle sounds, with the depth and feedback maxed you should be getting some heavy whoosh with a bit of throb.
Any way you could post some pics of the component side so we could see if maybe a part or two is off?
Here's one that's mostly stock. The trimpots are made external, and I used 9203 LDRs. But I wouldn't call it subtle
What do you think about the behavior described? (10K trim at 0 or no blinking, 1K trim at almost 100% or no sweep)
Here's a sound with 5 parts:
1- Guitar with Phase II off
2- Guitar with Phase II on, depth and feedback at 0
3- Guitar with Phase II on, depth 100% and feedback at 0
4- Guitar with Phase II on, depth 100% and feedback 100%
5- Guitar with Phase II on, depth 100% and feedback 100%, increased rate
Ringing a bell on something to anyone?
Here a sound with 4 parts:
It sounds right, but definitely not as intense as it should be. Verify all component values from R37-R46
Could we see pics of the component side of the board?
Oddly, this is about how my XC Phase sounds (everything seems to be soldered and wired correctly, and the jfets are matched). I opened a troubleshooting thread here but no solution was found, and, as you feel with your build, I feel certain that mine isn’t phasing nearly to the extent it is supposed to either. I hope you find a solution to your problem. Perhaps it will be something that I can apply to my own build to get an improvement.
Mike
No, it's right side up. That's the voltage converter
Well, I started with the assumption Robert always had all the IC with pin 1 top left !!! Thanks for correcting me, I should have looked at the build doc.
Easy spotting and guidance for you! Hard time to remove and resolder resistors for me :)
But now we talk!
Thank you very much DGWVI, you're the man. You made my week-end! Thanks all.
PedalPCB Phase II Kit fixed, 5 parts:
But now we talk!
Rad!!
Glad you got this one working. This is still my favorite phaser circuit, so I love seeing others' builds out there
