Ludovic
As a beginner with poor knowledge in electronic, I built the Phase II from a Musikding kit. I'm not that happy with the result.
1/ I have to fully close the 10K trimpot for the yellow LED to start blinking, and fully open the 1K trim to have a decent sweep.
In the end, the phase effect is very subtle, even with depth maxed out.
Is it possible the LED specs is not adapted to the circuit? How can I double check that? Is it worth trying to pair the led with an extra resistor? Which value? Or maybe I should replace the 10K trim by an higher one?
2/ I was expecting the phaser to periodically gently boost low ends during the sweep. That never happens. It this the normal behavior?
Thank you for any suggestion!
