MichaelW
- Build Rating
 - 2.00 star(s)
Well I built this pedal because @Bricksnbeatles said I needed one.
I really wasn't familiar with this circuit but it was designed by Howard Davis of Deluxe Memory Man fame.
It's an optical compressor with a blendable overdrive.
I rarely ever say this about any of my builds as I can usually find something I like about the pedals I've built. But honestly I think this thing sounds like crap.
(No knock on Bricksy....)
I'm not sure if I did something wrong or what. I guess I need to go listen to some more demo's of the real thing and see how far off I am.
Part of it was my expectations, I was expecting more "compressor" but this is really an overdrive pedal.
You can't turn the drive part off and even at it's lowest blend setting there's grit.
The overdrive sounds are thin and fizzy and underwhelming at best. I built it to the BOM, it uses a LOT of 1N914's and a single Ge diode. I used an ITT Red Band for the Ge, which is one of my favorite 1N34A subs.
There's quite a bit of compression on tap and you can get a ton of sustain with it, but in general the whole pedal sounds like there's a wool blanket over it.
The closest usable sounds I can get out of it is to turn the drive all the way down and run it in front of another drive pedal, but I don't see the point when there's so many other better sounding dedicated compressors I can use.
At full volume the pedal barely reaches unity gain, maybe a hair under.
I dunno, maybe I just don't get it, or I'm using it wrong. It was a fun build, but destined for the drawer.
Sorry Aion, this one's a total "miss" for me.
