Hi all,
3rd build, first two worked fine but this one is causing me to learn a lot.
I get bypass signal, but silence when effect engaged. I can see the Rate Indicator LED pulsing and the speed of that pulse changes with the speed pot.
So after a bit of inspection and forum reading, I built an audio probe. I followed the audio signal across the top of the schematic, and can hear the effected signal correctly until after C16. Going into r18 I can still hear it, but coming out it’s silence. I checked on the actual resistor leg coming in (to rule out my soldering) and I can hear it fine, but on the resistor leg coming out, silence.
Am I correct in assuming that this means the problem is here? My first time with an audio probe so I’m learning as I go.
Anyway, I desoldered R18 and checked with a LCR meter, but it says its fine and the correct resistance (1k). I swapped it anyway but no change.
Any suggestions on what to do next?
Cheers
Malcolm
FYI: Build doc is here https://docs.pedalpcb.com/project/Magnetron-PedalPCB.pdf
Cheers
Malcolm
