Check out how people use the Red Panda Bit Mixer.I bought one of these without really thinking it through. Are there any “in chain” uses for this?
It's here.Once we have the 3-way splitter (in progress) it’ll be really easy to parallel mix different effects and correct for phase if needed. Kind of like the EHX parallel mixer or other similar gizmos.
Pro tip: plug the 3-way splitter into the 3-channel mixer for the ultimate scatter/gather buffer!Once we have the 3-way splitter (in progress) it’ll be really easy to parallel mix different effects and correct for phase if needed. Kind of like the EHX parallel mixer or other similar gizmos.
I'll go one step further, put your favorite three buffers (or not buffers, euno the one) in those three branches.Pro tip: plug the 3-way splitter into the 3-channel mixer for the ultimate scatter/gather buffer!
I haven’t tried the tri parallel mixer but did briefly own the switchblade deluxe and in theory sounds like the perfect blender. You can turn on either loop or both and even switch the order of effects. Has phase correction also. But there was something about the drivers or impedances that just didn’t mix well. It was noisy and also introduced like a 1k or so frequency into the audio. It was weird.Once we have the 3-way splitter (in progress) it’ll be really easy to parallel mix different effects and correct for phase if needed. Kind of like the EHX parallel mixer or other similar gizmos.
Yes.Is this the 3-Channel Mixer or the 3-Channel Splitter?
Here you goTayda drill template for this?
