Chuck D. Bones
Circuit Wizard
The Audition board might be a contributing factor.  If the pot bodies are not grounded, that could cause oscillation too.  Only way to be sure is to box it up.  I've had varying luck on a breadboard.
			Narrowed down the problem to the 2.2 uf cap in C5.Or maybe you need a different pedal.
And I never honestly thought about the audition board, to be honest... very well could just be that.The Audition board might be a contributing factor. If the pot bodies are not grounded, that could cause oscillation too. Only way to be sure is to box it up. I've had varying luck on a breadboard.
Another stupid question I just now thought of... I once built a katana clone and the LED went bad... the Pedal developed a weird hum to it... swapped the bad flickering led and it was fine afterwards...The Audition board might be a contributing factor. If the pot bodies are not grounded, that could cause oscillation too. Only way to be sure is to box it up. I've had varying luck on a breadboard.
Lol, that you Hamish?"That might be the right move for someone who likes their sweet spot to be near noon and never deviates much in either direction. I know a guy on these forums who does just that."
Wow - I wonder who that could be?
Same here... I don't like maxing out controls or cutting them all together... I like having the "usable tones" in the center so I can go either way... because I feel like if I'm maxed out, there might be even more I like just beyond the horizonI think Chuck thinks I'm like that. In reality I often set controls in wildly unpredictable places. Sometimes I'll use treble at 11.00 or 1.00, or bass at 1.30. I just don't care. I'm crazy. Just today I played for over ten minutes with bass at 3.00! Sure, I put it back to noon afterwards but still - ten minutes!!
But really, when I work on a circuit for a pedal I am likely to use a lot I do try to get it sounding how I like with tone controls around noon. Then I have room to move either way. Gain and volume it's not such an issue. I have one pedal where I rarely raise gain above 9.00, and Chuck complains about that! You can't win. Sure, he knows more than I ever will, is generous with his knowledge and has helped me enormously to get sounds I like but he's so picky!
Just curious Chuck You mentioned the 4558d running out of bandwidth at higher gain. Do you have a suggestion for an alternate OpAmp I could drop in to remedy that issue?I saw another forum member have the same issue (also noted when the gain was turned up).
It doesn't really manifest in normal playing... but if you lightly touch a string you can hear it. I didn't make any other adjustments or modifications so its strange this would occur. You mentioned before that the 4558d op amp can only handle so much gain /bandwidth. Could this be the issue manifesting itself? or perhaps a different capacitor/resistor is needed in the gain section to compensate for the increased pot value.
Any suggestions for an op-amp that would
