MBFX
- Build Rating
- 5.00 star(s)
I built a Circulator last week, and can't stop messing with it! It's incredibly loud, but that isn't a huge problem. I'm enjoying running a fuzz into it. SWOOSH BEEYOWWWWWHOOOSH! Instant psychedelic insanity. The vibrato setting is ok, but definitely sounds better with a fuzz before it. It's a little too subtle clean unless it's dimed.
I'll probably build another at some point because I cracked the enclosure marking the drill holes with my center punch (hahaha), and modify it with a master volume trimpot for the phase side.
The build worked first try, and was easy to put together for being so complex. The hardest part was getting everything into the enclosure, because a cracked enclosure isn't easy to drill precisely. Definitely be careful with how hard you're hitting your center punch when you have multiple holes on the same plane. I cracked a powder coated pro enclosure from Stompboxparts, for reference - not something cheap and thin.
