j201 question
swelchy
grabbed 20 j201's from guitarpcb having a sale last week.. out of 20 pieces 5 tested as 2 diode junctions with the dca75pro.. that's a 25% failure rate? Should I cut my losses and be happy i got 15 good j201's or should I contact them? What would you do?
I had a bunch of way out spec 2n5457s from them last year. I never bothered to try to contact him, so I don't know how responsive he is about it. And I've found places where I can use these out-of-spec jfets (in buffers, etc.)
One thing to try is build a buffer with your bad ones and see if they buff. Do you have a breadboard? Or try the ROG measurements on them and see if they work as jfets.
just seeing what others comments were..... they definitely wont work for use as anything other than a diode since they tested on the dca75 pro that way
Well…. I guess I confirmed that guitarpcb has zero customer service… Wrote them an email just asking if they assume that failure rate was normal occurrence and crickets…. Never replied… At least I know what to expect and I won’t be ordering from them again.
Just now saw this post.
It's NOT a failed measurement. I've purchased hundreds of J201s from GuitarPCB and even this some of them test as 2 diode junctions with the DCA75 Pro, they are still good.
As with all JFETs, they are symmetrical (Drain & Source are interchangeable) and I've found that when that symmetry is perfect, it can fool even the DCA75.
To prove it, I used sockets in my builds and tried the ones that tested as 2 diode junctions. They still worked a treat.
Barry, at GuitarPCB is a lone operator and crazy busy. Best to contact him thru his forum.
Hmmmm…. maybe I spoke too soon? I guess I better throw them in one of my chop shop builds and give them a bias to see if they indeed are fine… I set them aside and labelled them just in case the tool was reading then weird. Thank you for the heads up and I may learn something from it…going to test them in a build later tonight to see.
That's exactly what I did with my first go-around with that DCA75 measurement result. Then I got curious and tested them anyway.
Looking forward to your results. Whatcha building?
haa... I have about 30 different builds in progress... You mean what are you going to actually finish... I have a couple chop shops I can use to test the jfets because they have sockets already there.
Oh no… should I invest in a DCA75 or DCA55?
I have a ton of J201s from him as well.
In my experience with buying hundreds of J201s from GuitarPCB, not one has been bad. I eventually hand tested every one of them with my DCA75. And those that read as 2 diode junctions actually worked when applied in a working circuit.
But for the sake of having an excellent piece of test gear, I highly recommend the DCA75 over the DCA55 because it shows more data about the tested device than the DCA55. The DCA75 also comes with Windows software for obtaining trace curves on BJTs, FETs, diodes, LEDs and other devices. (see attached image for some traces ran on two different JFETs)
In my experience with buying hundreds of J201s from GuitarPCB, not one has been bad. I eventually hand tested every one of them with my DCA75. And those that red as 2 diode junctions actually worked when applied in a working circuit.
View attachment 57894 View attachment 57895
Ok I’ll plan to get one. Are they quite a bit more expensive than the DCA55?
Digikey says they have some supply issues on the DCA75.
