the chorus is chorusing, the bias is carefully set, everything sounds good except when the pedal is engaged i'm loosing about 6dB from 500hz up (reamp box, pink noise, RTA, i'm not a cyborg). as soon as it's bypassed, the high end comes back. checked connections, checked components, nothing is sticking out. this high end loss applies across the board, even with the blend all the way down, which in theory should be almost untouched signal. this leads me to believe that the high end loss is either happening at the input before the split at the first IC, or after the blend knob.
i'm willing to admit i've lost all objectivity and could use another set of eyes on this. i overdid it with the pictures because my light is very aggressive and directional, and at the wrong angle it makes my solder joints look awful because of the shadow
