MIAB pedals
I waited.. an hour, two.. three.. no gutshots, no samples.. no schematic.. :)
Alright I don't have audio samples, but here's a gutshot and a schematic. B1-2/3-4 and D1-2/3-4 are each DPDT, B corresponding to brite and D to deep. Brite adds in or removes the bright caps, deep adds in or removes a fat V1 cathode bypass cap and a parallel cap to the bass control in the tonestack.
Thank you sir! Serious sfuff...
Volume pot straight into output jack? No buffer with line out? If so, it is about 170v p-p to tame (with volume maxed) :)
An accidental find.
Llano Estacado from Dos Rios Audio. Modded/cranked Plexi
I built a Golden Falk for a friend, but my fav is the PPCB Paradise Overdrive (clone of the Lovepedal Silver Jubilee).
@hamerfan I've been searching for a Silver Jubilee pedal to build. I keep hearing folks say the Alexander Jubilee Silver is the best, but I haven't found a schematic of that one. I suppose I should just give the Paradise a shot. It's cheap and low parts count, hardly a reason not to. In fact, the parts count is so low and the circuit so simple, it makes me skeptical it can pull off the Silver Jubilee thing. Lol
I see the Alexander has a 3 way tone stack while the Lovepedal has only a single tone control. This makes quite a difference.
I learned that the specific tone stack makes the amp.
Jubilee from Alexander Pedals
Some gutshot here: https://reverb.com/uk/item/51692202-alexander-pedals-jubilee-silver-overdrive-guitar-effects-pedal
One picture:
Guv'Nor?
