neiltheseal
Hey. I'm thinking of building a Boss SD-1 and wanted to know what as the most authentic pcb out there. Ideally I'd like to make the most authentic version but I don't know enough about this circuit to decide which. Any help is appreciated.
I have looked at the UberDrive obviously, but this schematic seems quite a bit different to the Aion FX version and the PCBGM version.
I assume that some of the differences are transistor related as the PedalPCB uses the 2sc732 which seem hard to get. Aion and PCBGM use easier to access transistors but seem to have two before the op amp whereas the PedalPCB version only has 1. Why is this?
Another difference is the pedal pcb version has diodes between pins 2 and 1 of the op amp (soft clipping?) but the other two have the diodes going to ground (hard clipping?). Surely these sound quite different.
