cdwillis
I actually picked this up in a trade yesterday. It's a 1975 Fender Twin Reverb. I doubled checked the transformer and chassis codes to verify. The previous owner changed out all the filter caps and did a general service on it.
1975 is an interesting year. I read that in '76 they added the master volume, but this one has the master volume and the pull boost on the knob already. It's still a 100w amp, not the 135w ultra linear setup that came out shortly afterwards. The master volume on this works really well which I was not expecting. There's a bright cap on it which I think helps keep some of the sparkle. I was thinking about changing it to a post phase inverter master volume and removing the boost, but I don't think I'll bother since the master works so well and I can just ignore the boost.
The vibrato channel sounds incredible. The normal channel is just sort of there and it doesn't nearly as much gain. Even cranked to 10 the normal channel stays clean. The vibrato channel will get dirty halfway up and it depends on the master volume level setting too. I might tweak the normal channel a little or see about adding the reverb to that side as well.
Right now it's got a Pyle and a 12t6 speaker in it. The guy I got it from had some other Eminences in it because he thought the speakers in it were too loose with the steel guitar he was playing. I'm doing a little research into replacement speakers. I see lots of people using WGS ET65s in Twins. The WGS 12c/s is another one. I'm interested in the Eminence Red White and Blues, also their Texas Heats. Seems like the lowest sensitivity speaker I can find that is still 50w is the Celestion A Type. It would be nice to have the lower sensitivity so that I could turn up the amp a little more without blowing my eardrums out.
