P phi1 Well-known member May 11, 2020 #2 Check the schematic to see what component it comes from, and use a wire to connect the components. Upvote 0 Downvote
metalguy55 Member May 11, 2020 #3 phi1 said: Check the schematic to see what component it comes from, and use a wire to connect the components. Click to expand... It's from the foot switch to the SW pad on the board. Upvote 0 Downvote
P phi1 Well-known member May 11, 2020 #6 The schematic should still show what component that pad goes to. Upvote 0 Downvote
metalguy55 Member May 11, 2020 #7 Robert said: Which board? Click to expand... Its the Simulcast board. Upvote 0 Downvote
PapaBear Well-known member May 11, 2020 #8 That' going to go to the 4.7k resistor right above the SW pad Upvote 0 Downvote
Robert Reverse Engineer May 11, 2020 #9 Yep, just connect a wire to the bottom end of R100 (4K7) Upvote 0 Downvote
metalguy55 Member May 12, 2020 #10 Robert said: Yep, just connect a wire to the bottom end of R100 (4K7) Click to expand... Thanks guys! Working on my first couple pedals. I'm making every single noobie mistake I read about before hand. It's hilarious. Upvote 0 Downvote
Many__Of__Horror Active member May 12, 2020 #11 metalguy55 said: Thanks guys! Working on my first couple pedals. I'm making every single noobie mistake I read about before hand. It's hilarious. Click to expand... We all started somewhere, you'll be an expert in no time Upvote 0 Downvote
MightySmallElectrons Active member May 12, 2020 #12 metalguy55 said: Thanks guys! Working on my first couple pedals. I'm making every single noobie mistake I read about before hand. It's hilarious. Click to expand... It seems so simple but I’ve laughed...I’ve cried...mostly cried. Upvote 0 Downvote
PapaBear Well-known member May 12, 2020 #13 Many__Of__Horror said: We all started somewhere, you'll be an expert in no time Click to expand... Every time I think I'm almost there I do something stupid to remind me I'm only human Upvote 0 Downvote
metalguy55 Member Jul 9, 2020 #14 It worked! I attached the wire to the bottom end of R100 like you guys were saying. After a while of debugging a couple other things I finally finished my first pedalpcb project, the Simulcast! Upvote 0 Downvote
Chuck D. Bones Circuit Wizard Jul 9, 2020 #15 Barry said: Every time I think I'm almost there I do something stupid to remind me I'm only human Click to expand... You're describing life on earth. ? Upvote 0 Downvote
