Soldered up the Crybaby and the Red Llama/Mosfet boost. I think the Mosfet boost was just shorting out on the enclosure, some tape fixed that up. The LED was also acting up, I changed it first (wrong thing to do, old one also worked and new one is now much brighter but I don't want to mess with it anymore), then I thought the ground wire on the 3PDT was badly soldered, but it turns out the ground wire from the switch to the enclosure was actually stuck and holding there, but not making a contact. Weird, but whatever, resoldered it and the LED now also works. So 2/3 pedals fixed, haven't opened up the Bad Monkey yet.
I did mess around a bit with the Electric Mistress, and it sounds pretty nice but there's a HUGE volume drop. Like 6-9dB or something. There are trimpots (it's based on the Markus W. etched PCB, 9V version) for bias, clock and feedback, but I don't think any of those affect the volume hugely? I think I might just try to get a veeeery small boost PCB with a trimmer and just plug that between the board output and the 3PDT here. But it would preferably have to work at 12V, or even better, both at 9V and 12V. Will have to start looking, the smaller the better, so maybe even SMD would be cool.
