- Build Rating
- 5.00 star(s)
So due to the glowing praise from quite a few people I respect on this forum, I was looking forward to this build and it didn't disappoint. I was itching to do a quick build over Thanksgiving and luckily I had everything I needed for this already in my inventory. And indeed it was a quick and easy build, with the the only caveat being the only C5K I had lying around had straight terminals instead of angled, so I had to wire it off board (how I even ended up with a straight pinned pot is a mystery).
This boost definitely lives up the hype; not only is it super clean but it has quite a bit of boost on tap. I compared it with another buffered clean boost, my FDIC (Fulltone 2B), and although they are quite similar in tone (with the germanium dynamics control on the FDIC dimed out), the Modus had loads more volume at its disposable. In addition, the FDIC has a wee bit of a softer, gentler hue to it (not in a bad way), while the Modus is a bit more dynamic.
I also compared it to my Texel, maybe unfairly so because they are completely different kinds of boosts, and the Texel won in every category you could think of except for the amount of boost on tap and simplicity: The Modus can go way loud, and it's hard to beat one-knobbers one it comes to how this was designed to be applied.
All in all, I can reccomend all three of these boosts. If a buffer is important, can't go wrong with either the Modus or the FDIC depending on what else you're looking for.
I'm certainly glad I built the Modus, but honestly I'm planning on building a second Texel, the king of all boosts: one for before and one for after my dirt
In conclusion, build one. I can't imagine one not having a use for it. Another 5 stars for PPCB
