Mentaltossflycoon
Moonn has a bunch of tiny projects that are fun like the tryhard.
				 www.pedalpcb.com
					www.pedalpcb.com
				I think the board would definitely fit but only in a certain orientation and in that orientation i dont the think the pots would make it fit if you used PCB mounted pots. You might be able to get away with it you didnt solder the pots directs to the board and bend out the legs.Would one of these fit?
Distortion 250 - PedalPCB.com
Compare to MXR Distortion+ / DOD Overdrive 250 Preampwww.pedalpcb.com
Ah. Could use solder lug pots if you’ve got them. Or try building someone in perf that you could make for the enclosure. Or just a simple a/b looper box might be handy I keep meaning to build one of those.I think the board would definitely fit but only in a certain orientation and in that orientation i dont the think the pots would make it fit if you used PCB mounted pots. You might be able to get away with it you didnt solder the pots directs to the board and bend out the legs.
Ecxactly many ways around and many ways to go about it! Thats the best part of making your own pedals!Ah. Could use solder lug pots if you’ve got them. Or try building someone in perf that you could make for the enclosure. Or just a simple a/b looper box might be handy I keep meaning to build one of those.
Variable high pass filter. But that's just me, sitting on several already built up HPF boards.So ive had this enclosure for a little while but i actually havent found a circuit that i want thatll fit in there! Originally i wanted to put the headphne AMP in here but the circuit itself is to big. Anybody have any suggestions on what you would do with this little guy?
Ohhhh how can i get my hands on one of these boards?Variable high pass filter. But that's just me, sitting on several already built up HPF boards.
Just have to pull the BOM together and it'll be ready to go public as an OSHpark share. Looks like I'm snowed in today, so maybe I'll be bored enough to get to it this afternoon.Ohhhh how can i get my hands on one of these boards?
Please keep us updated!Just have to pull the BOM together and it'll be ready to go public as an OSHpark share. Looks like I'm snowed in today, so maybe I'll be bored enough to get to it this afternoon.
Will do. I have a more uptown version on the bench right now too but it's still misbehaving a bit and sorting that out is my top priority for the moment. I have a feeling that whatever I learn there will be valuable for the simpler DIY oriented one as well, so I'd rather hold off on releasing the open source one until all my ducks are in a row.Please keep us updated!
Hey hey hey.....im patientWill do. I have a more uptown version on the bench right now too but it's still misbehaving a bit and sorting that out is my top priority for the moment. I have a feeling that whatever I learn there will be valuable for the simpler DIY oriented one as well, so I'd rather hold off on releasing the open source one until all my ducks are in a row.
I just went through the same thing with an older version of my DIY bass amp's HPF/PEQ last week, which I fixed but still don't know exactly how. So I need to work through the whole circuit methodically and get to the bottom of that. I really enjoy troubleshooting my own designs though, so all good!Hey hey hey.....im patient
Im itching to start making my own circuit designs i just need experience hopefully the new contest @temol just posted should help with that!I just went through the same thing with an older version of my DIY bass amp's HPF/PEQ last week, which I fixed but still don't know exactly how. So I need to work through the whole circuit methodically and get to the bottom of that. I really enjoy troubleshooting my own designs though, so all good!
have you tried this yet?Shove it up your butt!!
I just gave away the last of the 1590gs I had...have you tried this yet?
I'm guessing that there is something that you don't want to do with that.I just gave away the last of the 1590gs I had...
Can you advise me on performing this with a 1550j?
He's talking to himself again; who knows where his meds are? Find them, administer them.Shove it up your butt!!
