Here’s a tip for everyone- make sure you have your ground connected before spending 20 minutes troubleshooting
So was the signal generator a kit? How's it work? I need one.View attachment 68175
Probably the most useful thing I've built so far -- this is my test rig. It's a combination signal generator, audio probe, amplifier all in one. I'm trying to combine all of this with a power supply and possibly an oscilloscope in one consolidated enclosure. Regardless, this is the single most useful piece of equipment I own a this moment.
First pedal from the big lot checked and fixed, it was sold to me as "working", and frankly I guess it was. Deadastronautfx Abductor II I think? When turned on it worked fine, on bypass it only gave out a buzz, just had to swap two wires on the footswitch - very easy fix.
Sure calls for some labels and knobs though, since it's sort of an Echorec style pedal with normal controls (time, feedback, volume, mod depth and speed) plus volumes for the four separate delay "heads", and I think the switch is sort of a "sound on sound" style thing, which is cool to mess with although maybe not useful for normal songs and such.
Very cool pedal although the layout is cluttered as hell what with over a hundred parts, total of four PT2399's, couple of op amps and a bunch of transistors. The pots are also wired offboard I believe - very thankful that someone else built it up so I didn't have to.
Maybe I'll try my hand at some sharpie pedal art (and remove the white washer) since I'm thinking of keeping this one, maybe I'll do a shootout with the Hydra once I finish it since while they are different there is some overlap.
Looks like the kit I built a few months back. Picked it up as a “let’s see what Temu is about” order along with some toys for my cats lol. I think it was only like $3-5 at mostSo was the signal generator a kit? How's it work? I need one.
Do you know what's different about v1 and v2? I'm not 100% sure which one this is, didn't check the PCB for that.I have one of the first one Abductor delays done on a single sided layout. That was a fun build.
It had 5 knobs 4 switches and one stomp. Dead astronaut is still active over at diysb, you might get in touch with him.Do you know what's different about v1 and v2? I'm not 100% sure which one this is, didn't check the PCB for that.
Ahh, that clears it - I was only curious whether mine was v1 or v2, but that makes it clearIt had 5 knobs 4 switches and one stomp. Dead astronaut is still active over at diysb, you might get in touch with him.
I did a picture search and found the XR2206 kit. Was looking at pricing and found one that bills itself as better than the XR2206 with improved opamp and higher voltage. Price was right at $13.89. SUPPOSED to be in California, but the estimated delivery date is 11 days. Their address is 40 miles from my house, and it was listed as IN THE USA.Looks like the kit I built a few months back. Picked it up as a “let’s see what Temu is about” order along with some toys for my cats lol. I think it was only like $3-5 at most
Yep. Two for $14 at Amazon. https://www.amazon.com/dp/B097P4FRXT?psc=1&ref=ppx_yo2ov_dt_b_product_detailsSo was the signal generator a kit? How's it work? I need one.
Yep, same concept. I built the audio probe interface on a piece of perf board. Right now I'm just using screw terminals to connect the audio probe, but when I box this thing up, I'm going to have banana jack posts that will give me the ability to use all of my multimeter test leads, probe tips and clamps. I've got some power supply modules that will deliver 9-18V that I want to include, and I've been looking at an esp32 oscilloscope project that doesn't look too complicated to build. Right now, I'm trying to work out how to get all of this in one enclosure, and then I plan to mount my Auditorium Test Platform to the top.You should probably check out the fuzzdog ultra tester too. https://shop.pedalparts.co.uk/product/pcbulttest
