Ginsly
I’ve used these 3PDT pcbs with stripboard builds, and they work great:
I’m a little confused about how to use them with PedalPCB boards- if that’s even possible.
- in order to use the footswitch pcb for mounting the CLR & LED, it sounds like I need to jumper the CLR pad on the main PPCB as well as the LED pads.
- I’ll still connect In and Out at the bottom of the main pcb to the corresponding pads on the footswitch pcb. Do I need to connect ”SW” on the main pcb to “L” (led) on the 3pdt pcb?
- at this point, it looks like I have to connect the “9v(+)” and its “Ground(-)” at the TOP of the main pcb to “9v” and “G” on the 3pdt pcb. Do I leave ground “G” on the bottom of the main pcb open? Seems like there’s no place to connect it to the 3pdt… Then I’ll connect the DC jack to the side of the 3pdt pcb as shown in the picture- the way I do it with stripboard. Please correct me if I’m wrong.
- can I then connect both Tip and Ring of the Jacks to the corresponding footswitch pcb pads and leave the two Ground (sleeve) connections at the top of the main pcb open?
- I also use DC switching jacks since I install battery snaps. I connect black to Ring on the Input Jack and red to the middle DC Jack lug. Figured I’d mention it in case it was an issue here.
I realize I can just use PPCB footswitch boards, some of which have led pads. If I HAD to use this footswitch pcb with a PPCB project- could I? I’m pretty new to building, so this may help me understand more than the topic at hand. Thanks much!
