Hey all! This is my first post here, so if I missed any rules please let me know. Not new to pedal builds however which makes the mistake I made in this build more embarrassing, haha. I put the pots on the wrong side of the board, so they work in reverse. Well, not all the pots work in reverse. The bass and treble knobs work the correct way, which doesn't make sense to me. I've pulled the pots and am going to order some short leg pots to put on the correct side, but before I do I want to make sure that there are no other obvious issues to correct in the meantime. And yes, I did wire the switch correctly when I had the board in reverse, then when I pulled the pots and flipped the board I re-wired it.
Also, the normal channel doesnt seem to work. Master all the way up, bright channel all the way down, normal volume does nothing.
Polarized components seem to be in the correct way and none of the soldering looks dodgy to my eye on a first pass. Any guidance y'all can give would be appreciated!
Images before and after I pulled the pots out below:
