Kroars
I really hate to do this.  I recently had an issue with a TS808 popping, that @music6000 kindly pointed out that I had an incorrect resistor installed.  In that thread I had mentioned that I had a Skeptical Buffer doing the same thing.  After replacing the usual suspects for leaky caps (all checked out, but replaced anyway), I went one by one replacing every component on the pcb, including footswitch, all jacks and wiring.
I ended up ordering two more Skeptical Buffers, just finished them and they pop as well. One a lot louder than the other. I’m hoping someone can spot something that I’m missing or suggest a fix. Here are the three SB’s that are popping. I suppose I can Orman’s fix with the additional resistor and capacitor at the LED, but I’ve got to be missing something here.
Robert mentioned in one thread about a Cobalt popping “2M doesn't allow any DC bias to discharge from the 10uF capacitor quick enough”. I wonder if there is a similar issue with the 3M3 prior to output? I don’t see a schematic posted for this, though.
Thank you very much for any help.
