AionFX Lumitron Resonant Filter (Mu-tron III)
MattG
My band is covering "Shakedown Street" by the Grateful Dead. When we decided to add it to our set list, I bought an EHX Q-Tron Nano to get that distinctive "quacking" sound. The Q-Tron Nano works great---but it's not DIY. Before I bought it, I actually did a cursory search for a DIY envelope filter, but somehow I overlooked the Aion Lumitron Resonant Filter. Ultimately I did find it though, and finally finished it today.
This build gave me some grief. The enclosure is the Tayda "Chromium". The labels and graphic are from a Sunyscopa film-free waterslide decal. As a final step, I always do a heat treatment of the waterslide decal in an old toaster oven (that we no longer use for food). I always do an hour at 300F. It's never been a problem until now. As you can see from the pictures, the sides of the enclosure got "crinkled". The front face isn't too bad, except in the corners, where you can see a bit of wrinkling in the factory finish. It's almost like the factory finish is itself some kind of adhesive film, as opposed to a pigment that's truly bonded to the aluminum. Fortunately, that's just cosmetic, and I can't see the sides when it's on my board anyway.
This is one of my better drilling jobs: I have a drill press and a step bit, but I've always been too lazy to drill a pilot hole before using the stepper bit. And, more often than I'd like to admit, the stepper bit would move a bit when I started to drill, resulting in holes that were off just enough to be annoying. It only took me 50 or so builds to realize this is the ghetto way to drill an enclosure! So starting with this enclosure, I now use a regular bit to drill pilot holes. And boy does it make a difference!
Now to the inside... if you look closely at the smaller footswitch PCB, in the middle, on the top edge, there's a cutout intended for wire strain relief. These holes also exist on the right and left sides, but the middle cutout is special in that it actually protrudes from the top of the board, and adds a few millimeters to the height of the board. It just so happens, it made that board too tall to fit in the enclosure with the effect PCB. So, without bothering to check for traces, I just assumed there wouldn't be a trace routed along that protrusion, and I snipped it off to make the board fit.
As I'm sure many of you do, when I power up a build for the first time, I hit the bypass switch to see if the status LED comes on or not. And mine did not. My heart sank. But I went ahead and picked up the guitar, and lo and behold, everything actually worked (except the power-on LED). So I made yet another foolish assumption, that I installed the LED backwards. So I soldered in a new LED in the opposite orientation. But it still didn't come on. So I got out the DMM to see if either terminal of the LED had any voltage, and neither did.
So then I finally did what I should have done in the first place, which is to actually look at the traces to see how they route to the LED. Sure enough, the positive voltage trace for the status LED runs through the part of the board that I cut off! My solution was to use a 1R resistor to re-create the trace that I foolishly destroyed. I then covered the resistor in self-amalgamating tape to prevent it from causing a short.
Now everything works properly. There's actually a second LED that shows you the envelope in action. From Aion's documentation: "The footswitch PCB includes a second LED that shows the envelope. This correlates closely to the optocoupler LEDs that drive the filter, so it’s a good way of seeing the action directly." It's kind of fun to watch it pulse and fade with my playing.
Anyway, I only dabbled with it long enough to see if I could dial in a sound similar to how I had the Q-Tron set, and I was able to get quite close. I haven't even messed with the trimmer pot at all yet. It seems to me this Lumitron actually has a wider range of sounds available (it's not a Q-Tron clone, it's based on the Mu-Tron III; and I think the Q-Tron is not so much a Mu-Tron clone, but a derivation/cousin/inspired-by kind of thing).
Thanks for the build report. I was looking to build this one soon, mostly to mess with it in chain after the Super Heterodyne Receiver (Data Corrupter). Sounds like the footswitch hole needs to go a little lower than anticipated. Usually I order Tayda drilled/printed enclosures so this may be a tricky one to get right like that.
Great job. I have this one in the queue and looking forward to it. Not that it matters, and I don't know much about the Dead, but I thought Jerry used the MXR Envelope Filter? Have you tried the Waddle Box project. That one surprised me and has probably been my favorite EF I've built. Easy to use and gets the job done. Has a lot of quack but maybe too bright sounding for Shakedown.
I thought Jerry did use a Mu-tron. It certainly works for producing his tone, I build an Aion Lumitron for my sister-in-law who loves his sound.
I may have to look into one of these now. I’ve also had good luck with the MXR Envelope Filter getting the “Jerry Tone”, but it does things in a VERY different way (also a fun build I recommend folks checking out!)
Hopefully we'll see a pedalpcb mxr envelope filter.
TonePad has one, but if you do all the mods (added: emphasis pot, “direction” switch and “range” switch), the PCB mounted pots and switches of a PPCB build would be a lot easier to deal with! (I hate using flying leads for pots and switches!)
I just built one of the Aion FX Lumitron "kits" -- where they send you all the parts. Great pedal! I have used a vintage MuTron III and this is definitely the closest I've ever heard to that original pedal. Kudos to the fellow who runs AionFX.
The good:
Excellent pedal. Excellent circuit. Fantastic and easy instructions. Sounds exactly like the original MuTron III.
The not-as-good:
(this is for anyone who isn't used to building pedals) - this is a very tightly packed pedal, so you'll need to take your time and definitely have a sharp-point soldering iron.
Biasing of the circuit is all done by ear, so find your favorite recording of a MuTron III and reference that as you are biasing the circuit.
