AionFX Lumitron Resonant Filter (Mu-tron III)
MattG
My band is covering "Shakedown Street" by the Grateful Dead. When we decided to add it to our set list, I bought an EHX Q-Tron Nano to get that distinctive "quacking" sound. The Q-Tron Nano works great---but it's not DIY. Before I bought it, I actually did a cursory search for a DIY envelope filter, but somehow I overlooked the Aion Lumitron Resonant Filter. Ultimately I did find it though, and finally finished it today.
This build gave me some grief. The enclosure is the Tayda "Chromium". The labels and graphic are from a Sunyscopa film-free waterslide decal. As a final step, I always do a heat treatment of the waterslide decal in an old toaster oven (that we no longer use for food). I always do an hour at 300F. It's never been a problem until now. As you can see from the pictures, the sides of the enclosure got "crinkled". The front face isn't too bad, except in the corners, where you can see a bit of wrinkling in the factory finish. It's almost like the factory finish is itself some kind of adhesive film, as opposed to a pigment that's truly bonded to the aluminum. Fortunately, that's just cosmetic, and I can't see the sides when it's on my board anyway.
This is one of my better drilling jobs: I have a drill press and a step bit, but I've always been too lazy to drill a pilot hole before using the stepper bit. And, more often than I'd like to admit, the stepper bit would move a bit when I started to drill, resulting in holes that were off just enough to be annoying. It only took me 50 or so builds to realize this is the ghetto way to drill an enclosure! So starting with this enclosure, I now use a regular bit to drill pilot holes. And boy does it make a difference!
Now to the inside... if you look closely at the smaller footswitch PCB, in the middle, on the top edge, there's a cutout intended for wire strain relief. These holes also exist on the right and left sides, but the middle cutout is special in that it actually protrudes from the top of the board, and adds a few millimeters to the height of the board. It just so happens, it made that board too tall to fit in the enclosure with the effect PCB. So, without bothering to check for traces, I just assumed there wouldn't be a trace routed along that protrusion, and I snipped it off to make the board fit.
As I'm sure many of you do, when I power up a build for the first time, I hit the bypass switch to see if the status LED comes on or not. And mine did not. My heart sank. But I went ahead and picked up the guitar, and lo and behold, everything actually worked (except the power-on LED). So I made yet another foolish assumption, that I installed the LED backwards. So I soldered in a new LED in the opposite orientation. But it still didn't come on. So I got out the DMM to see if either terminal of the LED had any voltage, and neither did.
So then I finally did what I should have done in the first place, which is to actually look at the traces to see how they route to the LED. Sure enough, the positive voltage trace for the status LED runs through the part of the board that I cut off! My solution was to use a 1R resistor to re-create the trace that I foolishly destroyed. I then covered the resistor in self-amalgamating tape to prevent it from causing a short.
Now everything works properly. There's actually a second LED that shows you the envelope in action. From Aion's documentation: "The footswitch PCB includes a second LED that shows the envelope. This correlates closely to the optocoupler LEDs that drive the filter, so it’s a good way of seeing the action directly." It's kind of fun to watch it pulse and fade with my playing.
Anyway, I only dabbled with it long enough to see if I could dial in a sound similar to how I had the Q-Tron set, and I was able to get quite close. I haven't even messed with the trimmer pot at all yet. It seems to me this Lumitron actually has a wider range of sounds available (it's not a Q-Tron clone, it's based on the Mu-Tron III; and I think the Q-Tron is not so much a Mu-Tron clone, but a derivation/cousin/inspired-by kind of thing).
Thanks for the build report. I was looking to build this one soon, mostly to mess with it in chain after the Super Heterodyne Receiver (Data Corrupter). Sounds like the footswitch hole needs to go a little lower than anticipated. Usually I order Tayda drilled/printed enclosures so this may be a tricky one to get right like that.
Great job. I have this one in the queue and looking forward to it. Not that it matters, and I don't know much about the Dead, but I thought Jerry used the MXR Envelope Filter? Have you tried the Waddle Box project. That one surprised me and has probably been my favorite EF I've built. Easy to use and gets the job done. Has a lot of quack but maybe too bright sounding for Shakedown.
I thought Jerry did use a Mu-tron. It certainly works for producing his tone, I build an Aion Lumitron for my sister-in-law who loves his sound.
I may have to look into one of these now. I’ve also had good luck with the MXR Envelope Filter getting the “Jerry Tone”, but it does things in a VERY different way (also a fun build I recommend folks checking out!)
Hopefully we'll see a pedalpcb mxr envelope filter.
TonePad has one, but if you do all the mods (added: emphasis pot, “direction” switch and “range” switch), the PCB mounted pots and switches of a PPCB build would be a lot easier to deal with! (I hate using flying leads for pots and switches!)
I just built one of the Aion FX Lumitron "kits" -- where they send you all the parts. Great pedal! I have used a vintage MuTron III and this is definitely the closest I've ever heard to that original pedal. Kudos to the fellow who runs AionFX.
The good:
Excellent pedal. Excellent circuit. Fantastic and easy instructions. Sounds exactly like the original MuTron III.
The not-as-good:
(this is for anyone who isn't used to building pedals) - this is a very tightly packed pedal, so you'll need to take your time and definitely have a sharp-point soldering iron.
Biasing of the circuit is all done by ear, so find your favorite recording of a MuTron III and reference that as you are biasing the circuit.
I just ordered the Aion FX Lumitron kit. I had a real Mutron III back in the day. Huge mistake selling it. So, a while ago I bought an EH Nano Q-Tron. That was a disappointment. I had to sell it, I love to build projects. So, I read up, and I'm taking a chance on the Lumitron kit.
I bought the Lumitron kit when AION was running a 10% off sale on 7/6. Rec'd it via UPS 7/9. Assembled it today 7/11.
I originally thought (before I opened the package to inspect it) I'd strip the paint and make a sticker for the top to mimic a Mu-Tron III. But, the paint on this is so cool I'm going to leave it.
Along with the top controls, there is a "trimmer" control inside. I set mine around 9 o'clock to work best with my humbuckers.
This pedal sounds great. I haven't fully tested it with every type of guitar pickup, but I have Jerry Garcia quack dialed in using the FLEOR Alnico 5 bridge humbucker on my Firefly Pegasus and the Fender Lace Sensor (gold) bridge pickup on my MIM Strat.
In the '80's I owned a Musitronics Mu-Tron III. I stupidly sold it. Recently I decided to try to get that sound again. I bought the EH Nano Q-Tron and hated it. I tried several other cheap envelope filter pedals which were all very disappointing.
After I got this Lumitron pedal put together today, I set Sweep to UP, Filter to LP and Range to LO. Plugged in and, after some fiddling, heard that glorious duck fart quack sound again. A sound I haven't heard since I had the Mu-Tron.
View attachment 120581View attachment 120582
I've been tempted by Aion kits but have never bought one. My OCD is a little freaked out by those resistors. I'm confident that VandeKrol is sending out quality components, so don't let my neuroses be yours.
I've built a Lumitron, and it's still my favorite envelope filter. It's an extremely enjoyable circuit if you like turning knobs. The way the pots interact — not only with each other, but with the whole signal chain — is endlessly entertaining.
Hi genXslacker.
I was a bit "freaked out" by the red generic-looking resistors too. I have a good supply of high-quality 1% resistors in stock. But I measured every single one of the supplied resistors, and they were uncaningly close to the stated values. At least 1%'ers. I considered using my stock resistors, but opted to go with the ones that were supplied.
Ta boot... There are (3) 4558 op amps in this circuit and this pedal is dead quiet when engaged. I was shocked to hear nothing but glorious envelope filtering knowing that those 4558's can be noisy.
I want to thank MattG for starting this thread and sparking my interest in building this kit.
I have had a day and a half to evaluate this pedal with Telecasters, Strats, a P-90 partscaster, a 335 clone and my Firefly Pegasus. This pedal sounds great with all of them. I don't have a Mu-Tron III to directly compare it to, but I did have one for about two years and this thing sounds so close to it I can't detect a difference. I'm running it close to the beginning of my chain and have tried a compressor before it and without. It sounds good either way.
All the knobs have good usable range. There's also a red LED that lights when the effect is engaged and audible, which is kind of cool. To sweeten the pot, I really like having all the jacks on the front (top) of the pedal, instead of coming out the sides. It helps a lot in making it fit with my overcrowded pedalboard. I've been playing Shakedown Street and Fire On the Mountain like I haven't played them in years.
Hi genXslacker.
Don't get me wrong... I have high confidence in the quality of just about anything Aion puts out. My comment was more about my neuroses surrounding what I expect to see on my own builds.
I agree that it's a great circuit, and I tend to put mine at the front of the chain too. If there's a better envelope filter out there, I'm not aware of it.
I'm not 100% on this, but I seem to recall Kevin/Aion saying that he has those resistors custom made. They are high-quality/name-brand 1% (or better), he has the values printed on with numbers, to make it more approachable/eaiser for new builders who don't want to have to reference color codes or use a meter on every single one. I also seem to recall, you can actually rub or scratch the custom printing off and see the more common color bands underneath.
I had a feeling that was the case. As much emphasis as he puts on component quality in his writings, it would be quite surprising if he were putting crap resistors in his kits.
One of my first pedal builds was the Aion Luna.
The kits were a bit more in price than GGG or SBP but well worth it for the beginner.
Crystal clear instructions with everything marked and noted with painted and marked enclosure.
I think they are great for anyone wanting to try building pedals.
Hunting down all the right components can be intimidating for the beginner as is painting/graphics.
I've built several pedals and many other gadgets from scratch, searching out the parts etc... I've built other kits too. This is, by far, the best experience I've had building a pedal. My goal was to have a great-sounding envelope filter. Now, I've got one. The bonus is that I built it myself. :)
Kevin mentions,
Kevin mentions, somewhere on the Aion website, that they source their own resistors and they are 0.5% tolerance.
