I just built the Cattle Driver. It works, except the output volume seems way too low to me. Unity gain is just past 3:00 on the level control (i.e. a little past 75%). I'm thinking it's probably not supposed to be like that. I think it's working as-expected otherwise, though I can't be 100% sure, since I'm just going off online videos of the Cattle Driver and the Buffalo TD-X (of which the CD is supposed to be a clone). Other than the volume issue, there's no other obvious problems.
Does anyone else happen to have a Cattle Driver that's willing to take voltage readings for me to compare with, particularly around the op-amps? Otherwise, what's the most likely culprit to start with for debugging this?
Thanks!
Thanks!
