I tried finishing up the Chalumeau I have already populated (just missing pots and offboard wiring, plus the extra toggle for clean mod), but turns out the B1K pot I used for the previous Lizard Whatever was meant for the Chalumeau and now I'll need to do a new order to finish it up.
So I turned my attention to the ill-fated Hydra where I messed up by using tantalums for the 1uF caps, which were polarized and most of them were the wrong way around. But good news, I managed to desolder them and stick other 1uF caps in their place! Desoldering itself was a breeze (I'm using a thicker tip on the iron which I suspect helps a bunch there), although I still had a horrible time cleaning out the holes themselves (maybe I really need to invest in one of those fancier solder suckers instead of the blue cheapo). But I just stuck the new caps just partially through the holes with solder in (since it's hard to get them deep when you need to keep two holes melted at the same time), and I can report that it works just fine!
I'll look into maybe doing a build report tomorrow, for this and the Good Vibes both.
