Pedal2222
Thanks! No, it's a standard black powder coated hammond 1590BB enclosure.Is that the black sand texture enclosure from Tayda? Looks slick as heck!
It's a trick, I'm using a round piece of wood with a small hole on top. I stick the not needed one into the hole and press it out.Interested on the method you use for the SIP sockets. I see you punch out the ones not needed to keep it all together, whats the method for punching some out?
Thanks!Very nice
Cheers, I think I get it. Also that is the cleanest PCB I have ever seen after populating.It's a trick, I'm using a round piece of wood with a small hole on the top. I stick the not needed one in the hole and press it out.
All resistors and caps that used for the "silver pony mod" are in sockets. The extra 1M resistor (pulldown resistor) not exist in the original circuit. Here is also a socket. This one in combination with the bias resistor 1M (Vref) in parallel will give a input impedance of 500K, that's wrong. To make shure that the impendance stays 1M, use two 2M resistors here. That's what Bill Finnigan also does in the KTR version.Beautiful. How did you decide which parts to socket?
I used panasonic smf and ecq capacitors, the elko's are also from panasonic, those are used in the original klon centaur. The 1uF caps are from WIMA, that because the panasonic 1uF caps are to big for this pcb.what are you using for the 100n caps, and where from? those are nice and tidy. and the blue elecrolytics?
I like it clean, I use a special cleaner for pcb's ...Cheers, I think I get it. Also that is the cleanest PCB I have ever seen after populating.
thanks!I used panasonic smf and ecq capacitors, the elko's are also from panasonic, these are used in the original klon centaur. The 1uF caps are from WIMA, because the panasonic 1uF caps are to big for this pcb.
Thank you! The cleaner is a german product called: KONTAKT 360 Leiterplattenreiniger.wow that's beautiful! would love to see a post on how you get everything so neat... even your solder joints are perfect. What pub cleaner do you use?
