Ginsly
There are some upcoming builds that call for Jfets, and I've never used them before. I have a few through-hole J201s I got from Small Bear right before I started building last Dec, but I haven't set up a tester for them yet (no DCA75 sadly).
First - what is my best bet for Jfet sourcing these days? It sounds like SMD parts on a through-hole adapter are the way to go (?), but I'd love to hear some suggestions for low-hassle part numbers and where best to get them. I see that PedalPCB offers some already soldered to an adapter, and Aion does as well. I've seen J113, J201, and 2N5457 mentioned the most - not sure if they're more or less interchangeable. I assume places like Amazon are terrible for Jfets.
Secondly, I have a couple After Blaster 3pdt boards (courtesy @Feral Feline!) that call for a J113 (or J201, 2N5457, MPF201). In some cases I actually want the boost at the end of the circuit to NOT be clean, but to make a fuzz fuzzier, not just louder. Since I haven't worked with Jfets before, I'm not sure if I can expect one to do that. I'd love to use a BJT instead, but it's specifically set up for Jfets:
Is there any way to somehow use a BJT in place of the J201s I have? I've heard that @Chuck D. Bones might have some insight...
One of the PPCB Muffin Crumbs is similar and DOES use a BJT, but setting it up is a little less intuitive (especially powering it).
Thanks for any insights in this next step!
