Matopotato
@bluedmc777 : how did you drill "bars". Template only has holes and they do not match the bars that well either...
I would not use an ON-OFF-ON DPDT switch on this build, it was made for a DPDT ON-ON-ON switch.I just got the kit. It says on on on for dpdt, but I got on off on. Trying to read the schematic and figure out what works and not, but I couldn't figure it out.
My understanding is that On on on Dpdt have two versions on what connects in the middle position. Since type 1 or 2 is important for on on on and there is no mention of the type, I can only guess that on off on also works?
Feel free to expand @vigilante398
Thanks
There are drill templates for the Sushi C2CE PCB's boxes so you can get them machined at Taydas when you order the boxes, many other places will machine your box as well.@bluedmc777 : how did you drill "bars". Template only has holes and they do not match the bars that well either...
c2celectronics.com
Thanks for this!I would not use an ON-OFF-ON DPDT switch on this build, it was made for a DPDT ON-ON-ON switch.
The single SPDT switch is ON-OFF-ON but the DPDT switch should be ON-ON-ON.
The build document specifies a certain switch from Tayda so you could get the switching from that switch document.
Mini Toggle Switch 1M Series DPDT On-On-On Short Lever
DAILYWELL ELECTRONICS - Get It Fast - Same Day Shippingwww.taydaelectronics.com
Thanks for the drill template @Tassieviking. The one I got from https://drive.google.com/file/d/1AhgdvQF9y32I8An0m1vaOU9VhufoSSim/viewThere are drill templates for the Sushi C2CE PCB's boxes so you can get them machined at Taydas when you order the boxes, many other places will machine your box as well.
There are also basic paint files so Tayda can print the front of the box for youC2C Electronics - Tayda Drill Templates
It was requested that I put together some Tayda drill templates for my DIY projects for those that are inclined to use that sort of thing. These have all been verified for fit with the corresponding PCB. Please tag me in any build reports using these. Not because I need them for my records or...forum.pedalpcb.com
Drill Templates and Artwork Files
Due to the amount of time and logistics required for offering pre-drilled enclosures, I have made the decision that I will not be offering them going forward. I will continue to include drill templ…c2celectronics.com
If you use the drill template to mark out the holes yourself so you can drill them at home there are some things you should know.
1. All measurements are from the middle of the face, if you draw a cross in the middle of the front of the box you measure from there.
2. Left of center is a minus measurement. ( X axis)
3. Down from center is a minus measurement. (Y axis) (this one confused me to start with)
Just place some masking tape on the front and make a cross and go from there.
Start with the 12mm hole for the stomp switch and go from there, its on the center at the bottom so center is 0 on the X axis and near the bottom is - 48.931mm from the center of the box on the Y axis.
Good luck
Mick
Thanks.The drill template is there so you can get the enclosure machined at Tayda or any other machine shop, if I was to do it it home I think I would just pick a nice pattern and drill lots of holes.
The slots and holes are only there so you can see the tube, I don't think they are needed for cooling the tube so they are just decorative as far as I know.
All the drill files and art files are on the link at the C2CE shop, you might have to log in at Tayda to see them.
Tayda is very good with prices and I can save a fair bit using them for most of my shopping for stompboxes, try them out.
EDIT: Tayda has 1 type1 ON-ON-ON DPDT switch, its the blue one for 49cents.
Search results for: 'ON-ON-ON'
Thanks, was about to apologize for hogging and derailing your tread...This has turned into a very informative thread. I appreciate everyone that has contributed. I’m still on vacation so I’m not able to give any updates. The switch could be an easy culprit to overlook. Greatful for the feedback everyone.
Yea I’m not usually quick to troubleshoot because I rather be playing than pulling my hair out but new it’d be a quick and easy swap. Not sure if the Tung-Sol just didn’t have a good contact or if it maybe went bad on start up. I’d never had any issues with it being almost brand new. I’m gonna try it in my amp tonight. However I did break one tube in particle accelerato. An older TAD 7025s. Think I was trying to work it into the socket but had to pull it back out and doink…it the tip of enclosure. Didn’t break or release any gas or anything. Just didn’t work anymore.Great to hear!
We all know the feeling when a (temporarily) failing build finally kicks into life and sounds as it should!
Reminds me I should get my amp checked...
That’s how mine is. Lowest bass content in middle position. Sounds like it atleast.in the middle position for the switch both terminals provide ground connections that bypass resistors. if that is correct, that would be a setting where the most cut in frequencies would occur.
