Hm.. where do they join ?You're sending both windings of the transformer to one node.
Followed the switches wrong. My bad. Schematics on mobile...
Did you breadboard it before making the PCB?No worries, thanks for the help
I'm making a pcb now, let me know if anything else comes to your mind, i'll order it in the next few days, i can't wait to try it out![]()
I didn’t spot anything but I didn’t look very hard. I would breadboard and triple check any circuit I was making a PCB for tho!No, why?
I breadboard half of the stuff i want to make as a pcb but... most of the time breadboard pick up noise and weird stuff or the cables loose connexion and i have to be extra careful so now i just use a simluation falstad as much as i can and then make 5 pcs pcb at jlc for like 5$ shipped it's not too bad... then i can mod it or lift traces on the pcb as needed until i make another new pcb with the fixes....
Did you spot something wrong from what i posted here in the last post?
Ok, well i'll see how it goes, i'm starting to hate breadboarding... I used to do it a lot but i ended up spending more time trying to figure out what goes where and why there's noise or weird issues... having to check every cable i use and not move it around too much in fear of something falling off the breadboard... lolI didn’t spot anything but I didn’t look very hard. I would breadboard and triple check any circuit I was making a PCB for tho!![]()
Reminder to check out that Yamaha handbook. It's really well written. When I went to school for AE, it was the first book assigned to us. For a reference/educational book, it's very tolerable. Even some humor at times iirc.
Let me know what you think of this one.
I'll order a pcb and see how it goes from there.
Thats not how I understand it. If you have a series of devices connected together there is a possibility of creating a huge coil (loop) via ground. This coil can picks up all kinds of signal.if two different grounds from different circuits end up getting connected, they may actually be at slightly different voltages, which will cause interference (noise) because the voltage difference will create a current (this is commonly referred to as ground loop).
Ground is still established with the guitar. It's only the split signal from transformer that is isolated. It receives ground from the next device.Thats not how I understand it. If you have a series of devices connected together there is a possibility of creating a huge coil (loop) via ground. This coil can picks up all kinds of signal.
But a potential difference can hurt if your lips touch the microphone and create the ground loop. So groundlifting scares me. Please correct me if am wrong.
If your guitar amp and pedals are going to one circuit and FOH is on another circuit, you'll have a ground loop all the way back to the panel box.Ground is still established with the guitar. It's only the split signal from transformer that is isolated. It receives ground from the next device.
DIs work this way. Ground from the console.
