Buffered/Transformer Isolated Splitter
If you connect the Ring contact of the jack to the ground your sleeve will always be connected to the ground through an inserted mono jack connector.
Oh noooo, i missed that haha thanks
I was looking at is like it's making a stronger ground contact with the jack but yeah, that would have made the ground lift useless
Should i ground just the ring switch pin to ground or both ring pin and switch pin not connected at all?
I made the transformer and switches on a breadboard today to test it out.
Same as the last schem picture i posted here.
It behaves very very similar to the radial aby.
Phase switch works only when transformer in engaged, which makes sense because it would just shunt the signal to ground if it was possible to phase flip without the transformer engaged, right?
And there's something in the radial manual i'm not sure to understand.
It says to lift ground first, if not solving the hum, then activate the isolation transformer.
When i lift ground (on my breadboard version and with the real radial aby pedal) most of the time it will just hum like crazy, almost no guitar sound is heard in the amp speakers... How would a ground lift works without the transformer isolation? I mean a guitar amp input needs ground to work, not just the signal on the Tip... right? Or is it assumed that it's being used with 2 amps at the same time so it get's the ground from the other amp? In that case if i make the same circuit on both out A and B of my aby pedal, lifting grounds on both A and B would not make sense?
I would guess there are 3 buffers(1 in. 2 out) and it switches in the transformer.
Sorry @Nacht I did not see your question but I think other answered it !
I have myself a question, the pedal I built works awsome but it have a very loud and anoying pop noise when switching amps...
How can I fix that ? (I tryed to disconnect leds but no luck...)
(My schematic is in page 1)
Thanks !
