kylewetton
Here's the schematic, I'm wondering if any bright minds have ideas on where i should start with troubleshooting this, I've used the same ICs as recommended in the schematic
I’ve left all frequencies at midpoint (they’re slide pots, all B10K). A GE-7 is meant to boost or cut the level from the center on the level pot, so I’m confused by this one is cutting the signal in half at center. This is my own PCB. I’m hoping to not modify the schematic but instead try fix what is wrong with my PCB of this schematicAre you cutting a lot of frequencies?
Did you use 10k pots?
ELPCB, breadboard, or your own PCB?
You could add some gain to the last opamp stage if you wanted too...
Good point, my trace can be found in this Drive folderCan you post your schematic as well?
BTW where did that enclosure outline come from? I haven't seen that one before.
drive.google.com
Are you seeing stable voltages at your opamps? I don't see any decoupling caps any of the opamps (except the NE5532) and your traces are suspiciously thin, especially for the power rail.I don't know if this is helpful
Youre right, that 33K isn’t connected, good eye.Are you seeing stable voltages at your opamps? I don't see any decoupling caps any of the opamps (except the NE5532) and your traces are suspiciously thin, especially for the power rail.
The bottom 33KΩ resistor near the top appears to be grounded on both ends, if this is R31 or R33 in the schematic you linked, your 1/2VCC bias rail isn't going to work properly.
just looking again, I just be that 33K that’s the problem, I don’t know what I did there to mess that up so badAre you seeing stable voltages at your opamps? I don't see any decoupling caps any of the opamps (except the NE5532) and your traces are suspiciously thin, especially for the power rail.
My mistake, you’re right. I didn’t look close enough, I just noticed the 33k didn’t have any traces and missed the colors on the thermals.It looks like you have a VREF plane (red) rather than individual traces.
That’s correct, I’m away from my computer but I recall one plane is meant to be VREF, is this voltage divider even going to work with the way that 33K is connected to both planes? It almost looks like something that is technically correct to the KiCad but not actually dividing the voltage correctlyI see red spokes on the left ends of both of those 33K resistors.
The right end of the top 33K goes to VCC, the right end of the bottom 33K has blue spokes which appears to be your ground plane.
