leadfoot
I just wrapped up soldering a Panspermeria Fuzz PCB. When I plugged it in, I received very splattery inconsistent effect that didn't seem to pick up the playing of the guitar. So, I rechecked all my wiring, my soldering, etc. and that all looked fine. I then looked over the build document and saw that the PCB has an extra 10k resistor on the left hand side that the build document does not have. I desoldered that 10k resistor and went from having some sound to no sound when the effect is turned on.
I've verified:
1. power comes to the effect when turned on
2. 3dpt switch is operating as expected
3. all components are soldered correctly
4. all components are the correct values
I've attached an image of the pcb before I removed the 10k resistor in the lower left-hand side of the board and after. Is there something obvious I am missing? I had looked at the other Panspermeria Fuzz threads here before posting.
Thanks in advance for the help.
I've verified:
