SOLVED ADHD - squeal? Ish?
Lytt Effects
Ok, not exactly sure how to describe what’s going on, but basically my most recent build (newest iteration of ADHD w/ enhanced bypass board) is making a high pitched squealing noise. When pedal is in True Bypass mode, the noise only occurs when the pedal is engaged. When the pedal is in Buffered Bypass, the pedal makes noise at a much lower volume when bypassed, and then gets much louder when engaged. In all instances, the guitar comes through. Sounds perfectly normal when in TB, and sounds just fine when engaged, but the noise is very present.
I have not tested voltages anywhere yet, as I don’t know exactly what I’m looking for. I have not combed over resistor values yet, as my brain needs a break from it, so thought I’d bring it here in the meantime. I have tested with two different power supplies, both of which produce the same result, and both are known to be good supplies.
IMG_6930.jpeg IMG_6931.jpeg IMG_6932.jpeg IMG_6934.jpeg IMG_6935.jpeg IMG_6936.jpeg IMG_6938.jpeg IMG_6939.jpeg
Any change of you pull your in/out wiring away from the pcb?
Nope, no change. Didn’t get to do much troubleshooting tonight, so I’ll leave it for the morning before work.
Steps thus far:
- swapped power supply
- removed from enclosure and re-tested
- checked for bridges, gave another clean up wipe, brushed off board
Tomorrow, I will try swapping out the TL082, and then I will verify each resistor value. After that, I’ll start reflowing some joints, mainly on the tants, as they seem a bit off to my eye. Then I’ll get the audio probe out and see what’s what.
Voltages: Supply reading 8.81v at power jack, 8.56v at cathode of D100 (reverse polarity protection)
TL082:
  • Pin 1: 4.28v
  • Pin 2: 4.28v
  • Pin 3: 4.08v
  • Pin 4: 0.00v
  • Pin 5: 4.27v
  • Pin 6: 4.28v
  • Pin 7: 4.28v
  • Pin 8: 8.57v
Q1 (2N7000)
  • 1 (S): 4.28v
  • 2 (G): 4.28v
  • 3 (D): 4.28v
Q2 (2N7000)
  • 1 (S): 4.28v
  • 2 (G): 4.28v
  • 3 (D): 4.28v
Enhanced Bypass Board:
2N5457 (left)
  • 1 (D): 7.31v
  • 2 (G): 1.17v
  • 3 (S): 0v
2N5457 (right)
  • 1 (D): 7.31v
  • 2 (G): 1.17v
  • 3 (S): 0v
2SC1815
  • 1 (E): 3.05v
  • 2 (C): 5.51v
  • 3 (B): 3.51v
I believe I have the pinouts correct for the transistors. I'm reading the pins from left to right, 1-2-3, when looking from the top down. Flat face of the transistor is on the bottom. If that makes sense.
Schematic:
those jumpers for the diodes are not needed. I dont think they are related to your issue but I would remove them.
In narrowing it down it sounds like whatever the problem is has to be shared with the buffered bypass board and the circuit itself to me. If you can hear it in buffered bypass mode, assuming it is getting amplified by gain of the circuit when activated. Does the volume control effect the level of squeal when its not bypassed?
Welp, apparently Strymon 9V power supplies are a no-go for this circuit (the single wall supplies, not the actual power supply bricks). It seemed to me that all the voltages were correct based on the schematic, I triple checked all resistor values, and then got home from work and just had a hunch…
I used a new 9V battery to supply the power, and voila, no whirling squealy noise. I tested the Strymon supplies again (the supply I’ve used for the last year to test all 35+ builds thus far), and the noise was back. Put the pedal on my board and used my Cioks SOL to power it, no noise, worked like a charm.
Both supplies in the original testing were Strymon supplies, both of which produced the noise. Now I know!
Glad its solved.
It does sound suspect to me though.
Glad its solved.
You and me both. I powered it with the battery and it was fine, so I thought that surely it was something dumb, and simply unboxing it, pressing here and there, moving this wire and that, reboxing it… that was the fix. It’s happened. I then used both Strymon wall supplies to power it, both reproduced the noise. Used my Cioks brick supply to power it, no noise. Used the Strymon supplies again, noise. Back to the battery. No noise. Very bizarre. What I didn’t do was test the Strymon supplies in other pedals, but I would find it very odd if both happened to malfunction at the same exact time.
Any chance you could capture a clip of the noise?
Yes, will do. I will attempt to do so today or tomorrow and report back.
There you are, good sir.
I have had the same issue with other "cheaper" power supplies, different brands. I only had this noise issue with overdrive, distortion, or fuzz pedals. I switched to the 1 Spot, just the slim wall unit and I don't have this noise issue anymore with pedals, at least so far. I don't like using batteries. Can't say for sure with this pedal, have not built it yet. I have no clue what causes this. I could guess or assume it's cheap or out of spec parts in the power supply, I might be totally wrong, but it does seem very suspicious to me that only circuits that boost the signal reveal the noise from the power supply.
View attachment 84672View attachment 84673View attachment 84674View attachment 84675View attachment 84676View attachment 84677View attachment 84678View attachment 84679
mine does the same thing with the buffer/TB. I think the PCB might have some issues. I can’t figure out why it’s behaving the way it is. As far as I can tell everything is in the right place/orientation. I gave up on it. I’ve been having issues with other builds lately as well. Weird things that don’t make sense. The Octaclave I just finished works with a signal generator but not a guitar signal. Idk might be diodes? IC? Simple build. Surprised the heck out of me when it didn’t work. Everything is spot on correct with that one too. I ordered some new diodes and another LM741 but not holding my breath.
Head to the troubleshooting forum. Take plenty of pics and measurements according to the top few sticky threads. We'll sort it out.
Sounds to me like the power supply is using a switching regulator that skips clock cycles at light load, which effectively lowers the switching frequency down into the audio band. Lots of them do this, otherwise they'd have a hard time maintaining voltage regulation when there's barely any load. Add a dummy load across the power supply, maybe enough to draw something like 10mA or so, like a 1k resistor. This should keep the PSU at its normal switching frequency, outside the audio band. The cat might still complain though.
