Leprechaun/rainbow machine finally .... renamed again...
Riccardo Turacchio
So finally I finished this weird box and I love it
It was a smooth build but I have to say I got confused by the the led map....on the board say I for the led long leg but is actually the opposite..also i tried to dim the white led same as the red but even with almost 20k resistance still really bright...
I also inverted the dispersion pot....it makes more sense like this to me....
Still have to build an external passive attenuator to send control voltage in the expression input...next days....
But at the end is already one of my favourite effects....for those WTF moments....secret weapon
Ring Modulators.
You need more ring modulators, everyone ... needs more ring modulators.
Stick it in with the Hydra/Celsius build!
Really cool build on the Leprechaun and a great name for it.
Good to know....now after the second build I will take more care for the next
how did you make the box? Looks super cool
I made myself a couple of pseudo templates for my CNC machine....at least for the wood cutting and carving the aluminium is a foil 0.75mm ...the cnc can handle also this type of cut in 2 or 3 passages, then i have an adapter to use a marker for all the lettering and graphic elements ...I still have to hand fold the aluminium drill and assemble directly on the wood sides
