Hi, my Comprehensive Drive build worked well at first, but after a couple days it became a little buzzy/cheap sounding at even low drive and now is a complete fuzz-fest even when drive is at its lowest setting.  The signal is clean entering the IC, and coming out super distorted.  All components between IC input and IC output are outputting fuzz signal, including potentiometer in and out, as tested with an audio probe.  I have attached photos, showing the pedal with an audio probe temporarily installed.  Does anyone have any suggestions, advice or insight?  This is my third pedal build, after building two Propolis Fuzz.  I'm curious why it would start fine and then become messed up.  Maybe there was a short that ruined the chip itself?  I have a multimeter but I wouldn't know what exactly to test to see if this is the case.  Thanks ahead of time!
