Acrobat Parametric Distortion
Can you see my pic up top? It's about 1/3 of the way from the top, about even with the line of the middle pots, on the right wall.
kind of intrudes if you're looking to build a tight pedalboard, though, with a lot of side-by-side pedals, though--that might be annoying.
I think if I had to redo it, I might try to put it on the bottom wall between the 2 3pdts, right over top of that 8-pin 4007 IC--if it fits.
oh wait, you mean, how far from the bottom edge? I can measure exactly when I get home, but basically I just measured the pot dimensions (16mm I think) and measured half up from the board plus a little margin of error (10-12 mm), making sure I had adequate clearance from the bottom of the enclosure.
Ya from the bottom edge. I cant quite see in the pictures how close it is to the bottom/lid of enclosure. Im worried about board clearence. I like the position of your volume knob. Thanks for checking I really appreciate it.
Staying true to the heinously tight spirit of this board, you have about 1-2 mm of wiggle room.
Thanks again Comrade Hoser for the volume hack. I added the mod to my build last night, and I'm declaring this an *essential* mod. At lower volumes, the Height knob produces an apparent decrease in volume at full clockwise. The new volume knob compensates for that.
And also the volume (on my build, anyway), is insanely high on other settings.
I was inspired by this build.
I'm aiming to do this with mine, offboard wire the top-most gain pot, some Davies 1900 knobs ...
and no side-knob (was too lazy to photochop it out):
I guess you could cut the legs off the pots and use hookup wire. Pretty tight with all the jacks up there, but sounds like a plan.
Indeed, very tight.
I haven't mocked it up, but the A100k GAIN is already under the jacks; I'd be simply moving it over to one side a little, to make room for the VOLume pot.
GAIN & VOL would be 9mm pots, small enough compared to the stock GAIN pot. and with some little strips of vero to make the offboard wiring more easy.
9mm-pot-on-vero-vs-16mm-pot-png.88817
9mm left vs 16mm right, two 9mm pots are only 2mm wider than the one 16mm. With narrow knobs I think it's doable.
It's probably doable with Lugged 16mm pots. Or 1x9mm & 1x16mm.
Need to mock it up, still.
No cutting off legs required.
How is the Height pot wired? I'm trying to build the filter section on Vero and I can't tell how it works because the Build doc and schematic hasn't been released yet.
So, reading the pot from the prong side, we have from 3, 2, 1 A and the row below 3, 2, 1 B where 1 is the square pad.
Some things I can tell you for sure:
1A looks to connect to the left side of 2.2K resistor R18 under the 33n (C9) immediately below the rotary.
2A looks to connect to left side of 1R resistor R23, (confirmed by the title page PCB graphic on the site). The other side of R23 connects to bottommost pin, left side of rotary.
3A, on the reverse side of the pcb, looks to connect to both pin 2 of IC2 and bottom of R25 2.2K. Can't really see the trace well as the dual-gang is in the way, so I'm not super solid on that. And it's a PITA to remove and reinstall the board, so that's the best I can do.
1B connects to 2B.
3B looks to connect to the 3.3K resistor R38 (confirmed by title page PCB shot).
1B connects to 2B.
Hi Mate thanks, the A side seems to be consistent with the standard cut/boost config of an op-amp used in the Maestro filter.
Any idea if the B side pot is connected to the A side in anyway?
Oh wait, you mean is A1/2/3 connected to B1/2/3? No, I didn't see anything connecting.
Are they connected through components? Say a resistor or anything? Cause I'm a bit unsure of why they made it a dual gang if they dont work together to control the boost or cut.
I didn't see any linking traces on the board diagram, the component side, or the solder side, but again, traces on the solder side were very hard to suss out under the dual gang. I would have to desolder it because it can't lift.
I think Robert is the only one who can offer full confirmation of the layout, unless someone who has the board is willing to pitch in.
I assume you don't have the board and are trying to build it on vero? If so, how are you determining the layout and connections if you aren't referring to the PPCB schematic?
I’m trying to figure out differences in the key parts of the circuit, between this and the Maestro MPF-1 and then figure out the PDF Circuit as a variant of the MPF circuit.
Thank you for the tracing mate, I appreciate it.
