DailyDovetails
Try printing the outer wall first at a lower speed. That should get rid of the little bump which is likely ringing due to the quick change of direction.Belts tightened.
Although cura has some weirdness with the seam
Maybe I need to get a different slicing program or setup.
IDK maybe there's more to tweak.
If there is still a small gap bump up the extrusion a little until it goes away. It probably won’t dial in perfect tho. It’s about finding a happy medium.
If you mess with the extrusion you may have to bump up the first layer height a little.
I think it looks pretty good.
