Thanks. And yes, Cees was taken quite early.Looks awesome @Cybercow I wish I had been aware about these earlier. Very tragic with Cees passing, way too early.
I would like to build one of these.Thanks. And yes, Cees was taken quite early.
Just before he released his Purple Chorus, I had worked up a dual/stereo chorus of my own. Using two heavily modified Small Clone clone PCBs from GuitarPCB, I managed to create the 'Stereophonic Gizmotronic Symphonic Harmonic Perambulator Dual Chorus'. While Cees' Purple Chorus uses a single MN3207 BBD chip, mine uses two of either the MN3007 or MN3207 BBD chips one on each of the two PCBs.
View attachment 77712 View attachment 77713
If you want to build up one of these, I can provide more details and put you in touch with Spencer at AmplifyFun to get a finished, printed enclosure if you like.
Never got the Purple PCB from Cees. But the build docs can be found -> here <-@Cybercow Do you still have board and build documents for your project? I’ve been interested in the the “Purple” but doesn’t seem a layout or pcb exists. I bout a used Ibanez BC-9 bi mode chorus but they ranges were a little wild and they chorus didn’t blend well together. It was noisy as well.
@Cybercow Yea I’ve seen the build docs. Thats what led me on a wild goose chase to find a cob. A shame there’s no pcb available but maybe one day we will see one. I’m not advance enough to create a proper layout.Never got the Purple PCB from Cees. But the build docs can be found -> here <-
Linked above, but attached to https://forum.pedalpcb.com/threads/purple-chorus-analog-bi-chorus.21930/#post-277547Or a wiring diagram?
Not sure what "MILC" means, but looking at it, it appears to be just Cees' way of implementing the bypass LED. IMO, the 2N7000 is a bit of overkill with regard to driving the LED and his bypass switch wiring seems a bit unconventional is all.View attachment 96772
In terms of traces that are actually going to the circuit and not just wiring pins or jacks together, there are four: IN, OUT, INVOUT, and MILC. IN/OUT are obvious, and this particular pedal has an inverted output, which is INVOUT. But I can't figure out what the heck MILC is or what it's doing on the footswitch! The layout has all the LEDs on the PCB.
Here's the relevant part of the circuit from Cees' build doc. It's part of the power section.
Any thoughts?
