Pedal to 'Blackface' a Tweed Deluxe
psb962
I recently built a Tweed Deluxe, mainly from a Mojotone kit (with some substitutions), and love it. It's fat, bass-heavy, and has a harmonic palette that you have to hear because I can't describe it. I've been playing my vast selection of pedals through it and usually go back to no pedals, as most overdrives don't overdrive as well as the amp itself - but there is one exception: I found my Bluesbreaker clone makes the amp much less bass heavy, due to the active filters in that pedal that slice off a lot of bass. (I tried a treble booster (Naga Viper clone) and that was awful). But the experiment got me thinking, is there a pedal design I could build - ideally a pedalpcb project - that turns Tweed into Blackface? Clearly that would involve some mid scoop and a bit of treble lift to change the overall EQ from 5e3 to Blackface (Deluxe Reverb) territory.
Has anyone else been down this road? I'm guessing that the 3dB cutoff points of the filters in both amps are well different and the pedal would need to address that.
Here the amp, by the way. Highly recommend building a 5e3 if you have soldering skills from pedal work. Its very rewarding. PXL_20241119_212126933 (1).jpg
What about the 6 band equalizer? I built a slider version and it works great! With all sliders at 50% it has Unity, moving sliders up gives Gain/boost or down cuts just as one should expect with an active EQ.
Clean build, nice looking amp!! Mojotone makes good kits but just like pedals the finished product is a reflection of the builder.
I second the Equalizer suggestion. Besides doing what you need with the frequencies, you can also use it as a subtle boost—I think the main issue though is trying to maximize whatever clean headroom you can get out of it; when I think of Blackface v the earlier Fender variants, it's largely a progression of cleaner headroom. If you can get the signal just to the point where the preamp isn't beginning to distort, but is sending maximum signal to the power section, that's as much headroom as you'll get. Cutting the ample bass some will definitely help in this regard.
Nice work on the amp!
The Luxury 763 and Indiana Deluxe are both meant to be blackface IAB pedals.
Couldn't see any build reports on either in here. I think they would work on a vanilla amp but to tweak (specifically) the 5e3 to a 763 might need some engineering. I will try modeling the 763 in Spice and see what the overall EQ is.
Reactions: spi
Check out the Run off groove tone mender circuit. I’ve done a slight variation where I follow the tone stack from a Super Reverb.
Not sure it’s what you’re looking for but it will at least impart some of the EQ
If you play with the online Tone Stack Calculator, you can see that 3 band EQ stacks from amps typically scoop mids, and you have to turn the bass and treble down to get flat eq. Since the 5e3 doesn’t have a tone stack, it sounds like fuller mids by comparison.
On the other hand, a 3 band eq using op amps (like the EQD Tone Job) can be designed to flat eq with all three knobs at noon.
I modeled the 763 in LTSPice. The overall EQ doesn't have a mid scoop, just a distinct high boost. I don't think that pedal is going to make a 5e3 sound like a Blackface. I think I'll have to do some engineering to figure out how to do it.
Reactions: spi
Kudos for modeling it in spice. It’s a tweaked Timmy circuit, so I wouldn’t have expected to see a mid scoop.
I take all specific-amp-in-a-box pedal claims skeptically… doesn’t it depend a lot on what amp you’re running into? Unless it’s like an iridium - full amp/cab sim that’s meant to go DI. That said, Lovepedal’s AIB claims seem especially odd to me.
Yes, I think I'm looking to do something a little different here. An amp in the box is not going to be the same as a pedal that transforms the EQ of an existing amp into another fairly similar amp. So I will look at designing a pedal that cuts a little bit of bass, adds a little bit of mid scoop and a slight high-end lift and see if that works.
Of course, one minor problem is that I don't have a Blackface Deluxe Reverb to do a side-by-side comparison when I'm done, so don't take my word for it...!
Maybe try running the ROG Tone Mender circuit in spice and see if that gets you in the ballpark, then you could tweak capacitor values or try to match the exact amp values in the tone stack
You might have to scratch build a blackface amp head. I think someone mentioned it, have you checked out rob robinette’s site?
It's not really as simple as scooping some mids! The 5E3 is very low end heavy, not midrange heavy. And BF amps still have plenty of low end too, just not as much as a 5E3.
There are a few very simple things you can do to the amp before you even get to the pedals. Get the amp sounding right first before trying to apply a bandaid. I have built many 5E3s and my favourites are those that I have built to be properly biased and with some of that huge low end addressed. Nowadays i use a PT with a lower B+ which makes it easier to bias correctly but you can still bias a 5E3 correctly with the stock transformers. Because wall voltages are so much higher now the bias is usually way off and the 250R cathode resistor is no longer the right value.
It is unlikely that you have your amp biased to 100% plate dissipation with the stock 250 or 270R bias resistor. It's probably more like 120-140%. That will help your power tubes to wear out faster and your tone to actually be a bit brighter than it should be. I think Rob Robinette describes how to check the bias - it's not difficult. As the amp is cathode biased it just involves buying a few 5-10W resistors in various values - starting from 270R (250 is difficult to find these days) and going up to maybe 470R. I use ~10W Dale resistors from Mouser. (They look really cool!) I can tell you how to measure everything if you need. Note biasing to 100% plate dissipation is only recommended for cathode biasing. For fixed bias amps I usually prefer around 60%.
Once the amp is biased properly it will sound so much better and break up in a more musical way. I see you are using JJs - good choice. Just remember that JJs are rated at 14W rather than the 12W most 6V6s are. This is important when biasing.
Next I like to reduce the value of the coupling caps. I think in my last 5E3 in ended up with the first three caps at .022µF and used .033µF for the PI caps. It sounds drastic but you still have plenty of low end but a vastly more balanced sound which again, breaks up better because it's not loaded down with tons of bassiness. You could just replace the first gain stage cathode bypass cap with a 1µf cap for starters if you prefer. Caps are cheap and an easy way to tweak your amp. I like these: https://www.tubesandmore.com/products/capacitor-vishay-roederstein-630v-mkt1813-axial-lead
It will still sound like a 5E3 but a really good one! Then you can just use all the normal OD pedals you like.
The other thing to look at is obviously the speaker. The speaker has a huge impact on the sound and can dramatically affect how the amps sounds and responds. I like the Celestion G12H Creamback, but there are a gazillion options there, and mostly no more expensive than a cheap pedal.
You can obviously build an excellent amp - the pics show that! Don't be afraid to swap out some caps to get the amp sounding better. If you don't like it it takes minutes to change it back. Everyone who plays one of my tweaked 5E3s seems to prefer it to the stock versions. And FWIW the clean sounds are every bit as good as BF Fender if not better. A well sorted 5E3 is a wonderful pedal platform.
Nice info ^. I’m planning a build, I’d like to have the cap changes on a switch so that the full low end original circuit is still available. Obviously only 1 capacitor (cathode bypass) is easier to switch out than 4 (coupling). Would you say the 1uF Cathode bypass is a similar effect as the coupling changes?
I think the single capacitor switch option could be good for the OP since he likes the stock sound too.
I’l probably do that on my build, plus have the tonemender type pedal for mid scoop.
For reducing the bass, is there a big difference between cutting bass in a pedal before the amp, vs the capacitor changes within the amp?
Excellent post, lets talk 5e3 biasing and coupling caps as I think its important info.
First of all, the amp sounds great as is, I'm just trying to see if I can get other Fender-family tones out of it via a pedal rather than bypass or coupling cap mods.
I agree that 100% dissipation is ideal, so to get there with the 14w JJ 6v6s tubes I used a 270ohm cathode resistor on the power tubes, and Hammond transformers as they deliver the correct volts. After the circuit had had an hour powered up to settle down I measured the following readings:
AC Volts at receptacle: 122.1V
B1 379V, B2 331V, B3 243V - which are are close to historical norms
6v6 Cathode voltage = 21.5V
V3 Plate = 369V
V4 Plate = 366V
OT impedance from V3 plate to center tap = 179ohm, with 6.78V across it = 37.8mA
OT impedance from V4 plate to center tap = 243ohm, with 9.69V across it = 39.8mA
Power dissipation V3 = (369-21.5)*37.8E-3 = 13.1W
Power dissipation V4 = (366-21.5)*39.8E-3 = 13.7W
...I decided those were close enough.
I've read a lot on possible coupling cap and bias cap changes, and as I understand it, yours are as follows:
Both V1 -> V2a coupling caps replace 0.1uF with 0.022uF
V2a -> V2b coupling cap leave stock (0.022uF)
Both V2b -> V3/V4 coupling caps replace 0.1uF with 0.033uF
So yes, that will filter out a lot of bass. If you also change the 25uF bypass cap on V1 to 1uF that will do same.
I guess what I'm trying to do is pre-filter the guitar signal so that it has similar effect to all those cap changes.
Finally, I agree on the importance of the speaker, but I went for the '5E3 Speed Shop' A12Q which - according to the forums - is an even better replica of the old Jensen P12R than the ubiquitous Weber 12A125. It certainly delivers! I haven't heard a 5e3 with a Creamback - wouldn't that preserve more middle and bass than a Jensen - clone? I think one of the reasons that a Jensen is traditionally used in the circuit is that it offsets the bass. I can see why you made cap changes if you weren't using a Jensen-like speaker. Have you tried yours with a Jensen or similar?
Well it certainly sounds like you have things under control! My apologies if I came across as "Mr Knowitall"! I always see the 270R cathode resistor as a red flag because it's what is usually supplied in kits and it's usually wrong for the reasons mentioned.
I have used various speakers in a 5E3 and settled on the G12H Creamback simply because I love how it sounds. I have used various Jensens and Webers as well but have never got along with them, alnico or ceramic. I used to use a Celestion Gold but found that I like the G12H more. The G12M Creamback is great in a 5E3 too.
I just find that now that I have got rid of a lot of the excess low end the amp is a lot more useful. I don't really see the point in keeping it - and I do like a big fat full tone. The speakers don't like it and it makes using pedals more difficult too.
My big thing about overdrive pedals is all about having control over the low end. If I find an OD I like the first thing I do is work out how to add a bass pot, to both add and subtract low frequencies. It has been a total gamechanger for me. It's frustrating to me that more pedals don't have a Bass control. I find it vital for using different guitars into the same amp, especially as some of my favourite amps have no Bass pot.
Of course there is no right and wrong in all of this - it's what I like and you may not.
I finally got around to modding the 5e3 to tame the low end and decided to go with The Edge mods - 12AX7 in V1, and swap both phase inverter coupling caps from 0.1 to 0.022uF. It works! Low end is much nicer, and amp sounds sweeter (if that's the right word). So I think that will do for mods to the amp. I know a lot of people change the coupling caps between V1 and V2 instead, but according to my spice model that has far less effect, so I did it the Edge way.
I also discovered that Barber makes a pedal called the Barb-EQ that has switches and pots to help the user change the voice of a Tweed to a Blackface, and various other combinations. So when someone reverse engineers that one, I'll build it.....
Awesome, I've just now got my chassis up and running, first amp build from scratch. Good info to see here. The bass is huge, I'm probably also gonna mod to tame it. Though, I'm running through my Valve Jr 12" cab, so I'll wait till I have the speaker and cab for the 5e3 before making any final decisions. I saw that BarbEQ in the 5-watt video, wonder how similar it sounds to the ROG Tone Mender. (The tone mender doesn't exactly follow the Fender BMT component values, but could be adjusted to do so)
Oh very nice. I may give this a try. I can no longer hear bass frequencies from years of playing, but it’s worth a shot.
That's a bit sad! It's usually the high frequencies which go first.
I've read about the Barb-EQ, and that's a cool idea. There are quite a few ways to tweak the identity of your amp, without necessarily tweaking the actual amp. That's where amp in a box pedals come in. They don't always change things how you might hope because so much depends on you, your guitar and your amp. But sometimes a pedal can just work with an amp and make sounds that make you happy. Again, it's why I like adding bass controls to overdrive pedals. It can make pedals which are not so useful into something perfect.
