mybud
Long story short, this gadget below arrived in today's mailbox. It's a genuine Fender 4 way Tele switch to address some problems with my Tele neck pickup.
Details follow: Of late, my Tele neck pickup doesn't function according to plan. There's a big discrepancy between signal levels between the bridge and neck pickups. Neck passes some audio but it's hardly there to speak of. Once in a while it functions ok but generally not.
I tried a temporary touchup on some suspect joints but this hasn't resolved the situation.
I assume (always risky) that the switch is shot. Hence the replacement as above.
The plan: I aim to replace all the offboard wiring (pots, selector switch, and so on). The current setup is two 250k pots and a 47nF cap. I have two B500k pots and would like to use these to avoid special ordering two pricey 250k replacements.
I'm following the four way selector wiring instructions as detailed by https://sixstringsupplies.co.uk/. They claim that 500k pots increase the guitar's brightness which TMM is undesirable. So I thought of increasing the cap's value, say to 56 or 68nF to compensate and start out with the darker sound which I myself prefer.
The alternative is to place two 510k resistors across the appropriate pot terminals, which would at least theoretically get me in the correct ballpark (nearer 250k) and keep the 47nF cap in place. I'm not overly concerned about the pots' taper, since I generally set volume to max and have a preferred tone setting (dark, as before).
Apologies for the lengthy post. Any advice, guidance, or public castigation (within reason) for jumping to conclusions on my part
gladly received.
