What’s on *YOUR* workbench?
Are those 072 measurements in reference to input ground or with both prodes on the +- pins of the 072?
I’ve taken the IC out, so measuring between both the power pins and and input ground.
It actually starts at +9v and drops over time to +1 - +0.6
Negative is steady at -17.7 which is higher than it should be, or lower or … you know what I mean!
Sorry. I made something and it didn’t work
No apple-pollywoggies me droogie, 'tis on your workbench, no?
This thread is about anything on our workbenches. So — ALL GOOD.
It was all in goo... I was just messin' 'round. When you see any of my posts, 90% of the time it's off-topic attempts at humour.
The "silly" clue in the post you quoted was "stupid-memes", as I was the one most recently posting a stupid-meme.
On the count of "filling threads with meaningless dribble..."
I plead guilty. May the court have mercy on me.
Luke, maybe something up with how you're filtering power to/from the charge-pump IC?
The drop seems like the big cap filling slowly up and then/or being drained slowly...
Sure you've got the correct pinout of the CP-IC?
Sorry, thrashing around in the deep end trying to pretend I can swim with the big trouble-shooting fish.
It works! Lack of connection between 9v pin on the charge pump and the D101 - must have damaged the trace somehow… solder bridge across and it’s working! Running at +-17.7v rather than 15 but nothing seems to be blowing up so we won’t complain!!
I’ll do a build report
Occasionally happens in manufacturing. Nice job tracking it down.
I've been working on a little wave shaper that's an amalgamation of Escobedo's SSWSMS and precision rectifier (that you can dial in between half and full wave rectified)
Taken a little bit of work including finding out I had a dodgy batch of diodes AND a dead op-amp, and something real weird going on with the output buffer. With that being said with a sine input I can get triangle + square waves out, and the rectifier really opens up what you can do.
It's got a massive treble reduction that's happening somewhere in the circuit (that isn't just the AR gen), but aside from that does exactly what I had hoped it would do.
Sounds...very strange through a guitar. Square/triangle sounds exactly what you think it would sound like, half wave sounds like a ring mod (great with chords!) and full wave is your classic octave effect.
Did you know they make prototype board for SMD stuff? It's even double-sided. The holes all go to the ground plane on the back.
Here's today's prototype: a low power (long battery life) headphone amp. Puts out >0.1W into 16 ohms (that will blow both your ears and earbuds off!) and draws only 0.3mA at idle (in a mono version). The tradeoff is a bit more THD than a "HiFi" headphone amp -- whatever that is. Something like 0.25% at 16 ohms. Gets lower with higher Z headphones. Who cares though? It's meant for instruments, not audiophiles.
I haven't been building pedals for a while (although I should fix one popping issue and do some bass modding at least), mainly because I wanted to get to know what I built a bit better.
And that turned into another whole music project using that pedal 👀
But at least the plan is to just shit out something without spending an eternity polishing it, so I get a good "excuse" to maybe learn a bit more about bass, practice music theory, write lyrics and maybe even sing for the first time on an actual song. I also have a drum programming course I'm working through I thought I'd practice here too.
Of course the thing is that writing the songs is the fun part, and the rest of it is a lot of work, and that's where a lot of projects falter, so we'll see... At least I'm trying to stick to 3 songs max.
Done!
My workbench is often virtual these days, but here's is what's on it anyway. Today's PCB. Looked cute enough that I sent it straight to JLCPCB without triple-checking, in a time-dishonoured tradition. I mean, what could possibly go wrong? 💥🔥🌪️
