YesAre you talking about what looks like a crack coming from pin 8?
Your guess is as goos as mine.Is that blue-ish spot on pin 6 just a glare or is that some sort of arc mark?
Pretty random.
Not really my problem i guess just don’t like something i built breaking.
AwesomeWell, it is the randomizer IC. It understood the assignment.
I'm going to offer to send the guy another IC and hopefully that'll take care of it. Worst case scenario another microcontroller bites the dust, we'll recover.
Ya know i was thinking it worked prior to shipping. If it was wrapped in just regular plastic/bubble wrap. Vibrations etc could thr electro static discharge through the enclosure/jacks/pots somehow.Delayed ESD result maybe?
More likely it would have occured before or during assembly. Did you build it in the winter by chance?Ya know i was thinking it worked prior to shipping. If it was wrapped in just regular plastic/bubble wrap. Vibrations etc could thr electro static discharge through the enclosure/jacks/pots somehow.
Yea i did. My area winters are wet and mild mostly. Cant recall if i built it around one of our not so common dry/cold stretches.More likely it would have occured before or during assembly. Did you build it in the winter by chance?
Were you wearing wool socks?Yea i did. My area winters are wet and mild mostly. Cant recall if i built it around one of our not so common dry/cold stretches.
No. But it could damage the chip and cause an internal short or other damage that results in a short. ESD damage isn't always immediately apparent.Were you wearing wool socks?![]()
Could ESD really blow a chip up like that where it blows apart?
